1961 Imperial parking brake
LouisHarper
Posted 2018-03-08 5:33 PM (#559475)
Subject: 1961 Imperial parking brake
Has anyone ever re-done the parking brake assembly for a 61 Imp? Mine does not click in place and the cable to the trans is pretty rusty.
FINS!
Posted 2018-03-09 7:28 PM (#559554 - in reply to #559475)
Subject: RE: 1961 Imperial parking brake
5001002525
The parking brake cables are available reproduction. You should be able to clean up and lube the parking brake assembly and getting working. If no luck with that I should have a good one.
LouisHarper
Posted 2018-03-09 9:19 PM (#559563 - in reply to #559475)
Subject: Re: 1961 Imperial parking brake
Thanks. Where do they sell the cables?
mobileparts
Posted 2018-04-03 2:14 PM (#561053 - in reply to #559475)
Better than reproduction -- that are garbage -- I have REAL ones -- nice and juicy thick.......
Call me -- Craig -- 516 - 485 - 1935 ..... West Hempstead, New York....
Also, the parking brake shoes -- and 1 last N.O.S. Emergency Brake Drum, if you need...............
Edited by mobileparts 2018-04-03 2:16 PM
Tigersmith
Posted 2018-06-23 5:49 PM (#565513 - in reply to #561053)
Craig.... Is the 61 Imperial Cable and 61 Windsor cable the same part? I have no brake at all on my newly acquired Windsor, Haven't had a chance to get under and see what the problems are with this...
Drew
mobileparts
Posted 2018-07-18 6:57 PM (#566823 - in reply to #559475)
Imperial is different on EVERYTHING.......
Not in library often during the summer / car show season......
CALL -- 516 - 485 - 1935......
