Location: NY & VT | Need a cheap 15" alternative to the stock 14" Mopar wheels... what will work? |
| Depending on how wide you want them a Chrysler 5 th ave ,Plymouth Grand Fury, Dodge Dipolmat ,some 1/2 ton Dodge Trucks .From the Early to late Eightys .as long as they are 4 1/2 inch bolt centers . |
Location: Lower Mainland BC | 57DODGECONV - 2018-03-17 5:17 PM
Depending on how wide you want them a Chrysler 5th Ave ,Plymouth Grand Fury, Dodge Diplomat , some 1/2 ton Dodge Trucks . From the Early to late Eightys .as long as they are 4 1/2 inch bolt centers .
Not sure about the trucks but I know that the RWD mid-80's 5th Avenue and Dodge Diplomat work. My NOS parts guy is running normal 5th Ave/Dodge Diplomat wheels on his 55 Dodge CR convertible which gave me the incentive to search out 85 Diplomat cop car wheels so I could fit wider radial tires on my 56 Dodge. Found a set with Dog dishes for US$200. Key requirement is the 4.5" bolt circle.
Edited by 56D500boy 2018-03-17 5:45 PM
| Some of the 70-80s Dodge Trucks have the 4 1/2 bolt pattern . |
Location: NorCal | Another thing to consider is the center hole diameter, factory wheels measure 2.800"-2.810". Anything smaller obviously won't fit and anything larger depends on the lugs to center the wheel........some think this isn't desirable. |
My main motivation is availability of new and reasonably priced radials to replace 8.50 x 14, not available anymore in P225/75R14 but is available still for 15" wheels, plus I alwys thought 14's seemed too small. Width would need to accommodate the afromentioned 225/75R15 tires (Firestone). No way do I want overpriced crappy repros from Co_ker (ugh) et al.
Edited by firedome 2018-03-19 1:39 PM
Location: northern germany | also check the offset, should be 0.5" positive. |
Location: Seville, OH | Some Ford wheels have a center hole only that is only slightly smaller than a MoPar hub. I used 68 Ford station wagon wheels on my 57 Dodge for a long time. Just had to open the center hole a tiny bit. |
