60 dart nylon window guide rollers
60 dart
Posted 2018-04-09 8:50 PM (#561333)
Subject: 60 dart nylon window guide rollers
500020001000100100100100252525
who's got em new or what is being used in place of -----------------------------------------later
Edited by 60 dart 2018-04-09 8:51 PM
ttotired
Posted 2018-04-14 6:32 PM (#561626 - in reply to #561333)
Subject: Re: 60 dart nylon window guide rollers
500020001000100100252525
I just used old ones Chuck
I think GM also used similar ones
Not much help though
60 dart
Posted 2018-04-14 7:54 PM (#561630 - in reply to #561333)
the one in the car is broke . the two extra i haver are cracked . i've eyed the gm ones and the cost are high for a tiny piece of round nylon . i'm thinkin i can make a couple using normal backyard shop
tools but we'll see . sometimes its easy to create something , sometimes not . thanks perth for a response -----------------------------------later
pssssss. i have a wood lathe to use , its just not here but 35 miles away at my parents garage , i've had there
for over 20yrs . might be time to bring it home
Leadfoot1000
Posted 2018-04-15 2:41 AM (#561651 - in reply to #561333)
Subject: RE: 60 dart nylon window guide rollers
100100
Here’s a link to some on epay. They were an exact replacement for the quarter windows on my 57. https://www.ebay.com/p/1964-64-Barracuda-Quarter-Window-Regulator-Ro...
Edit: measurements are provided in the details so you can check fitment.
Edited by Leadfoot1000 2018-04-15 2:55 AM
60 dart
Posted 2018-04-15 4:11 AM (#561652 - in reply to #561333)
thanks but the center hole looks to be way to big ---------------------------------------------------------------later
60 dart
Posted 2018-04-23 12:40 AM (#562099 - in reply to #561333)
my dad once said the older ya get the dumber ya get and i guess he's right . the roller in the back door i thought is broke but even more , the little bracket it's riveted to is what came off , broke the weld
on the window channel . now for the real dumb part . the spares i have aren't brittle broke at all . uuhhhhh i didn't have my reading glasses on and looked cracked from where i was standing and the glass/channels
being on top the mini fridge on top of the work bench . hell they look and feel new , all of them except for being somewhat stiff after almost 60 yrs. . the one that broke off the window channel might be welded
back on even with leaving the glass/channel intact . what i think may have broke it off was 2 things . my adding new thicker sweep and the factory roller guide being way too tight from the factory . my main concern
is that most all my spare glass and on the car now glass has sanding marks before i owned them . so i guess i'll get em working properly for now and polish later . the broke off bracket and roller are now soaking
in a mild acid bath to get rid of pretty much all the rust even under the roller and see what i have left to work with metal wise ------------------------------------------------------later
