Cross ram
   Forward Look Swap Meet -> For Sale - PARTSMessage format
haspe
Posted 2018-04-11 3:40 PM (#561411)
Subject: Cross ram
I believe its a 1960, comes with exhaust manifolds (manifold heat risers not working), rebuilt original carbs, most of the linkage, air cleaners that someone modified and cut off the sides (I assume they wanted more air). Has one or two broken bolt heads in the exhaust manifolds, no rot in the aluminum. I few pinholes in the "exhaust to intake manifold tubes". One broken flange on a small cast iron piece (have the piece). Missing the tube that goes between the two sides and booth of the "center mounting plates" .
Good condition. Supposedly the original owner did not like how cold blooded they were and changed over to 4bbl soon after buying the car new.
$2,800 plus freight
Forward look family
Posted 2018-07-03 10:43 AM (#565941 - in reply to #561411)
Subject: Re: Cross ram
Do you still have your cross ram setup for sale, if so would you break up the set, I have the intakes, mounting flanges, and cross over tube but I need exhaust manifolds, linkages, and carbs.
