56 Powerflite reaction shaft seals
Bporter
Posted 2018-04-11 8:00 PM (#561426)
Subject: 56 Powerflite reaction shaft seals
My 56 Coronets Powerflite is currently being rebuilt. The kit arrived without the two torque converter reaction shaft seals and the company says they are no longer available to them in a note on their website. Apparently it's a 56 only issue because the man doing the work had a set from a slightly newer powerflite that did not fit.My originals were broken. He has one more source but if that doesn't pan out... Have any of you run in to this issue and,if so, did you find a usable substitute?
Posted 2018-04-11 8:58 PM (#561429 - in reply to #561426)
Subject: RE: 56 Powerflite reaction shaft seals
500020002000500100100100100
If you can identify the parts by number and name from the diagram and list below, I can find the PN for you (if you don't have it). And do a quick search for that part. (I have a NOS parts guy local to me).
(55-56PowerFlitePartsDiagram.jpg)
(55-56PowerFlitePartsNameList.jpg)
Attachments 55-56PowerFlitePartsDiagram.jpg (132KB - 196 downloads)
Attachments 55-56PowerFlitePartsNameList.jpg (204KB - 146 downloads)
Bporter
Posted 2018-04-12 12:57 PM (#561462 - in reply to #561426)
Subject: Re: 56 Powerflite reaction shaft seals
On your exploded view the two rings are #20. According to Fatsco where the kit came from 56s are a different size than other years which I guess is why they cant get them. Marvin Hughes, who is doing the rebuild, tried a set from a powerflite a year or so newer with no luck. If you and your local guy can help that would be great. Thankyou.
Posted 2018-04-12 2:31 PM (#561474 - in reply to #561462)
Bporter - 2018-04-12 12:57 PM
Item 20 in the diagram leads to a reference to Section 21-129-13 which leads to the PN 1312 746. Searching with Google on "1312746 ring" (no space) gets me an eBay find and an additional pdf that might be useful.
https://www.ebay.com/itm/NOS-MOPAR-1953-57-TORQUE-CONVERTER-REACTION...
http://www.joeandhenrytransmissions.com/partscatalog/powerflite.pdf
Edited by 56D500boy 2018-04-12 2:35 PM
(55-56PowerFliteReactionRingPN1312746.jpg)
Attachments 55-56PowerFliteReactionRingPN1312746.jpg (205KB - 148 downloads)
Bporter
Posted 2018-04-12 4:36 PM (#561486 - in reply to #561429)
Thank You! I will check both of these out.
Posted 2018-04-13 12:50 PM (#561546 - in reply to #561426)
20001000500100100252525
In the ATP brand the rings are PR-4.
