starter motor for a 413 engine, cross ram
di_ch_NY56
Posted 2018-04-22 1:34 PM (#562073)
Subject: starter motor for a 413 engine, cross ram
I got two starter motor with my Letter. Installed was a 1889 100 motor and by packed a 1889 200 motor. Which one is the correct? Or is it another starter motor?
Happy Restoring!
Dieter
60Mopars
Posted 2018-04-25 4:53 AM (#562248 - in reply to #562073)
Subject: RE: starter motor for a 413 engine, cross ram
Hi Dieter! According to my parts book no 1889200 is correct for all 413.
Have a nice day
Jan
Posted 2018-04-25 6:07 AM (#562250 - in reply to #562073)
Subject: Re: starter motor for a 413 engine, cross ram
50005000100050010010010025
As always, a couple of photos will help Dieter. I know the which one that's the correct starter if you post photos.
di_ch_NY56
Posted 2018-05-11 10:09 AM (#563134 - in reply to #562250)
wizard - 2018-04-24 12:07 PM As always, a couple of photos will help Dieter. I know the which one that's the correct starter if you post photos.
this is the 1889 200 starter, according an answer and the Parts Manual book, chapter 8. Interesting is that both starters (1889 200 and 1889 100) have the same number on the cone and the same count of teeth at the tooth wheel. The 100 starter is slightly shorter. I only cleaned the 1889 200 starter because it's the apparently the correct starter motor.
Happy Restoring!
Dieter
(IMG_4954_starter 1889200.JPG)
(IMG_4955_starter_cone_number.JPG)
Attachments IMG_4954_starter 1889200.JPG (164KB - 51 downloads)
Attachments IMG_4955_starter_cone_number.JPG (155KB - 49 downloads)
Direwolfe
Posted 2018-06-18 4:06 PM (#565298 - in reply to #563134)
The '200 is the one for my '61 cross ram.
