Type A transmission fluid Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Adamopar |
Member Posts: 6 | Hello, I am currently looking into changing my tranny fluid in my '55 Plymouth and the manual calls for Type A fluid. Obviously this type of transmission fluid is and has been obsolete for decades now. I have heard that Dexron is the modern "replacement/equivalent" so to speak, but I don't want to risk anything before finding out if it is safe to do so. Any help would be appreciated. Thanks, Adam | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Adamopar - 2018-04-29 7:32 PM Hello, I am currently looking into changing my tranny fluid in my '55 Plymouth and the manual calls for Type A fluid. Obviously this type of transmission fluid is and has been obsolete for decades now. I have heard that Dexron is the modern "replacement/equivalent" so to speak, but I don't want to risk anything before finding out if it is safe to do so. Any help would be appreciated. Thanks, Adam I have used Dexron in all my cars and marine transmissions that called for Type A for many years. No ill effects to date! Greg | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | Greg is correct, of course, but you can still find Type A if you really want it. I've seen it on shelves in some of our "dollar stores" and I think it may be used in some tractors. | ||
Expert 5K+ Posts: 5006 | Dexron VI for me | ||
Adamopar |
Member Posts: 6 | Thank you for clarifying this for me. Much appreciated! | ||
ram300 |
Extreme Veteran Posts: 363 | I use type F fluid, supposedly it gives a firmer shift. | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | the company "Shell" make the type A. Worked fantastic on my rebuild Torqueflite. | ||
62 413 |
Veteran Posts: 296 Location: South Central PA | As said above,on the old stuff,Type F is is the best choice. | ||
Expert 5K+ Posts: 9667 Location: So. Cal | You're not going to risk anything with a powerflite trans. Those things are almost indestructible. They were designed to work fine with motor oil if necessary. I wouldn't stress about which type you use. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | For winter driving, my factory service manual states that you can drain a quart of transmission fluid and replace it with a quart of kerosene. I think the trans will be able to handle the newer fluids just fine. | ||
Expert Posts: 3777 Location: NorCal | Two observations; 1) The new Type A isn't the same as the old type A; the old Type A was based on sperm oil...no longer available. 2) The newer Dexron/Mercon and ATF+4 fluids are formulated for use with lockup converters and, to prevent shudder, they want the lockup clutch to slip on engagement. The lockup clutch in the converter isn't any different than the bands and clutches in the transmission so the newer fluid will cause them to slip on engagement too. If that's OK with you............... | ||
