Manual disc/drum master cylinder '59 Sierra Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Cataldo |
Regular Posts: 50 Location: Apple Valley, CA | Hello, I am having a whole bunch of trouble figuring out what master cylinder to get. I want to run the scarebird front disc kit with factory 11" drums on an ebody rear end. What master cylinder do I need? 1 1/16? 1 1/8"? What bore size? And what application should i get? Thank you | ||
Expert Posts: 3776 Location: NorCal | Just did the same swap on my '57 Sierra; tried the 1 1/32" MC and the pedal was too low, changed to the 1 1/8" MC and have a good pedal. The Dodge Ram calipers require a lot of fluid volume. I used a Raybestos MC39178 MC with a 4-bolt to 2-bolt adapter. Edited by 57chizler 2018-05-01 2:50 PM (MC.jpg) (mc-adapter.jpg) Attachments ---------------- MC.jpg (23KB - 211 downloads) mc-adapter.jpg (10KB - 204 downloads) | ||
Expert 5K+ Posts: 5006 | where and what make is that adapter?
that one looks good, the mopar ones dont that riser area...
https://www.summitracing.com/parts/dcc-5249315/overview/
https://www.summitracing.com/parts/clp-mca-m
bingo.... Bing found it... http://www.doctordiff.com/master-cylinder-adapter.html
Edited by mikes2nd 2018-05-01 3:47 PM | ||
Cataldo |
Regular Posts: 50 Location: Apple Valley, CA | So that was with 1 1/8 master and MANUAL brakes? | ||
Cataldo |
Regular Posts: 50 Location: Apple Valley, CA | Ok... so I have spent a whole lot of time trying to find a 1 1/8 master cylinder that bolts up. M1404 seems like the winner, it is the "hemi" master. I dont care about originality, at autozone it is the only one i can find and it is remanufactured. What is another 1 1/8 master cylinder??? | ||
Expert Posts: 3776 Location: NorCal | mikes2nd - 2018-05-01 12:40 PM where and what make is that adapter? that one looks good, the mopar ones dont that riser Doctor Diff. http://www.doctordiff.com/master-cylinder-adapter.html And, yes, manual brakes. Edited by 57chizler 2018-05-02 12:17 PM | ||
Cataldo |
Regular Posts: 50 Location: Apple Valley, CA | Ah great. Rear drum brakes as well? What size wheel cylinders? What proportioner are you running? How is the pedal, i just ordered a m1404 which is s disc drum master from a 1970 Charger with a 1 1/8 bore | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | https://www.classicindustries.com/product/1969/dodge/charger/parts/m... https://www.pentastarparts.com.au/store/index.php?l=product_detail&p... https://www.carolinaclassictrucks.com/MC571.html https://www.classicindustries.com/product/1974/dodge/all-models/part... http://therammaninc.com/products/shop_list/Disc-Master-Cylinders-35... | ||
Expert Posts: 3776 Location: NorCal | Cataldo - 2018-05-03 4:46 PM Ah great. Rear drum brakes as well? What size wheel cylinders? What proportioner are you running? Yes, rear drums with 15/16" cylinders. I used the Wilwood 260-11179 combo valve. (Wilwood 260-11179.jpg) (CIMG0693 (Small).JPG) Attachments ---------------- Wilwood 260-11179.jpg (124KB - 210 downloads) CIMG0693 (Small).JPG (167KB - 208 downloads) | ||
Expert 5K+ Posts: 5006 | i think I'm going with that master cylinder you posted. I have power brakes though so the back cylinder is kind of hard to check Fill it with a tube... I will have to use an "offset" adapter plate also since its going in a hemi. I was thinking about this also but its very small, only a 1 inch bore. https://www.amazon.com/Wilwood-260-7563-Tandem-Master-Cylinder/dp/B0... | ||
