1955 dodge custom royal
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
hondaman1974
Posted 2018-05-09 3:47 PM (#563036)
Subject: 1955 dodge custom royal
100252525
hello, just about to send fca the info for my 1955 dodge custom royal. is there anything I need to know prior to sending title info and money? thanks in advance!!!
Posted 2018-05-09 4:11 PM (#563038 - in reply to #563036)
Subject: RE: 1955 dodge custom royal
5000200020005001001001002525
hondaman1974 - 2018-05-09 3:47 PM
Yeh, don't get your hopes up for a lot of good information. The best will be the IBM card and the engine number verification.
Good luck.
hondaman1974
Posted 2018-05-10 9:26 AM (#563083 - in reply to #563036)
Subject: Re: 1955 dodge custom royal
100252525
is the ibm card the body tag? my 55 is early and doesn't have one (was told they came on later 55's?) also my engine is long gone. I guess for starters is get the broadcast sheet from fca and go from there
Posted 2018-05-10 12:34 PM (#563093 - in reply to #563083)
hondaman1974 - 2018-05-10 9:26 AM
Don't know about 1955 Dodge body tags but I am pretty sure that you will NOT get a broadcast sheet from FCA. At best you will get a letter and a copy of the IBM card image. (The IBM cards were put onto microfiche and then destroyed (or they burnt in some fire) - which is too bad because back in the day, the IBM card and the broadcast sheet were probably linked by a card reader/printer system (now long gone)).
Some people have found broadcast sheets taped to the top of the cardboard glove box shell - or under the rear seat - or under the carpet - or nothing.
An example IBM card image (my car) and a thread in which attempts are made to decifer the card:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64614&...
Good luck.
Edited by 56D500boy 2018-05-10 12:48 PM
hondaman1974
Posted 2018-05-11 12:44 PM (#563151 - in reply to #563036)
100252525
56d500, thanks for the info. I was reading some past threads it seems like they do not accept payment? is this true? also I haven't tranfered the title in my name. would that make a difference?
Posted 2018-05-11 1:41 PM (#563156 - in reply to #563151)
hondaman1974 - 2018-05-11 12:44 PM
Not sure about the accepting payment comment but I do know that if you can't prove that you are the registered (titled) owner, then they are not going to provide you with anything and would return your check uncashed.
hondaman1974
Posted 2018-05-11 2:07 PM (#563158 - in reply to #563036)
100252525
gotcha!!! will keep you posted on what happens
