gear oil question
49pair
Posted 2018-05-15 11:39 AM (#563434)
Subject: gear oil question
I am not sure I have ever seen this answered. I have the early style limited slip used from 58 to mid sixties that I will be using. Would it hurt to use synthetic gear oil in that unit or should I use conventional gear oil? What about additives?
LostDeere59
Posted 2018-05-15 2:03 PM (#563447 - in reply to #563434)
Subject: RE: gear oil question
100100100100
To the best of MY knowledge there is no issue with using synthetic in an older limited slip unit. If someone knows otherwise I'd be interested to know as well.
As far as additives it depends on what you want.
Most additives are put in limited slip units to reduce chattering during turns. This seems like a good idea until you think about why the unit is chattering, and why you put the LS in in the first place. Additives reduce chatter by allowing the friction components in the LS unit to slip more easily, preventing chatter when the axles are forced to move at different speeds as when turning.
What many folks don't realize is this also allows those same components to slip more easily when driving straight - kinda defeats the purpose of the LS in my opinion.
I had an 01 F350 with a clutch type LS in it that chattered a little from day one. It ran synthetic w/o additives, and I serviced it according to the factory schedule. After 140K the chatter never got worse, and I never found clutch material in the oil when I drained it. On the other hand that truck was an animal in the snow and could push snow like nobody's business. So for me a little chatter was just a reminder that the diff was working
Gregg
Posted 2018-05-15 2:06 PM (#563449 - in reply to #563434)
20001000500100100252525
I've used synthetic in the clutch-type Sure-Grips for years. Red Line is my preferred brand, it meets all the Chrysler specs for limited-slip differentials.
(RL 75W-90.jpg)
Attachments RL 75W-90.jpg (53KB - 101 downloads)
Posted 2018-05-15 10:43 PM (#563486 - in reply to #563434)
Subject: Re: gear oil question
5000
2nd for red line... or Royal Purple
di_ch_NY56
Posted 2018-05-20 3:35 AM (#563671 - in reply to #563434)
100050025
Thanks a lot for your proposals.
