'57 - '58 Stop Light Switch
Rob
Posted 2018-06-10 9:17 PM (#564990)
Subject: '57 - '58 Stop Light Switch
500100100100100252525
I know this question has been asked before; Does anyone know of a bracket that can mount a brake light switch to the pedal on a '57 - '58 Plymouth? That pressure activated switch on the master cylinder does not work all that well, I'd rather have the switch on the pedal like a modern car.
mobileparts
Posted 2018-06-11 12:13 PM (#565022 - in reply to #564990)
Subject: Re: '57 - '58 Stop Light Switch
I have the CORRECT (SLS29 Standard -- OBSOLETE) Stop Lite Switch for 1955 - 1961 (ALL) Mopar Products.....
and I have the other two -- behind the pedal -- frequently used......
Call me -- Craig -- 516 - 485 - 1935 .... West Hempstead, New York......
Posted 2018-06-11 1:01 PM (#565025 - in reply to #564990)
20001000100100100
you can get adjustable ones.
http://www.ronfrancis.com/prodinfo.asp?number=SW%2D42
or better working ones.
http://www.ronfrancis.com/prodinfo.asp?number=SW%2D32
go modern mechanical(even hit up a pick a part for 10$) all cars in the junk yard have these.
https://www.amazon.com/Wells-DR496-Brake-Light-Switch/dp/B0026NAWPC/...
i dont like this one, that little nut seems iffy...
https://www.ebay.com/itm/Universal-Street-Rod-Adjustable-Brake-Light...
Rob
Posted 2018-06-18 8:43 PM (#565306 - in reply to #564990)
Thank you for all your replies, this is what I was looking for.
