Fan Clutch for 1960 New Yorker with 413
rexc
Posted 2018-07-06 3:35 PM (#566136)
Subject: Fan Clutch for 1960 New Yorker with 413
Dear Gang,
I am trying to replace the fan clutch on my 1960 New Yorker. So far, nothing I have ordered that supposedly will fit is correct. The shafts are either too long or too short. I finally installed the short clutch but it is about 1.5 or 2" from the radiator, which seems too far.
I am sure someone out there knows a correct replacement for the fan clutch and would greatly appreciate any help. The fan clutch that I removed was not ancient, but it had not revealing numbers to help me.
Thanks!
Rex
Posted 2018-07-06 4:31 PM (#566142 - in reply to #566136)
Subject: Re: Fan Clutch for 1960 New Yorker with 413
5000200020005001002525
Did you try Rockauto? They have an array of different sizes available. Just measure out the height of your old one to compare to the new one's specs with the "info" button.
https://www.rockauto.com/en/catalog/chrysler,1960,new+yorker,6.7...
rexc
Posted 2018-07-06 5:00 PM (#566148 - in reply to #566142)
Thanks, but none of those they have listed as fitting are correct; they are too long or too short. I love Rock Auto for lots of things, but their info. is not always accurate for the old stuff.
Posted 2018-07-06 5:15 PM (#566150 - in reply to #566136)
50002000100100100100
What length are you looking for? The Mopar Performance unit worked for a stock radiator and stock BB in my 1960 Plymouth perfectly. I have a part# for a replacement unit, if you want I can try to find it. Actually I have one of these for sale, but I'm located in Germany.
b5rt
Posted 2018-07-06 9:21 PM (#566174 - in reply to #566136)
Let us know if this works. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68317&...
rexc
Posted 2018-07-07 8:32 AM (#566192 - in reply to #566150)
I would love to have the part number! Thanks! Rex
rexc
Posted 2018-07-07 8:37 AM (#566194 - in reply to #566136)
Subject: RE: Fan Clutch for 1960 New Yorker with 413
Dear All,
I just looked and the Hayden 2947 is the clutch I just installed. It does fit and work, but it is almost 2" away from the radiator which seem a bit too far away. Thanks to everyone for the help!
Best,
Rex
Posted 2018-07-07 10:01 AM (#566207 - in reply to #566136)
500050002000100025
Heres the old thread about the Hayden 2765 (Jaguar) fan clutch. The fan clutch has worked perfectly over the 5 years since installed.
My car is used for active driving, highway, city or cruising.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=46435&...
Posted 2018-07-07 10:09 AM (#566209 - in reply to #566192)
rexc - 2018-07-07 8:32 AM
Thermal fan clutch 36952. Hope this helps.
Posted 2018-07-07 11:23 AM (#566212 - in reply to #566209)
50002000100100
I installed one on my 60 Saratoga last summer, it was off an early 70s Mopar.
(fan.JPG)
Attachments fan.JPG (106KB - 186 downloads)
R41HP
Posted 2018-07-26 12:30 PM (#567220 - in reply to #566209)
1001002525
1960fury - 2018-07-07 9:09 AM
I have 36952 noted as Four Seasons brand on a box for a Temp-Guard TFC-49 I used.
Interchanges also listed:
Everco A8198
Kool Clutch 115049
Hayden 2705
Murray 271305
Billohio
Posted 2018-08-21 10:26 AM (#568753 - in reply to #566136)
I had my original rebuilt at kirkconnel corvette in florida. probably not as cheap as a new one but will fit
