1956 Dodge Custom Royal Badges and emblems
Gbreslin
Posted 2018-07-22 2:29 PM (#567013)
Subject: 1956 Dodge Custom Royal Badges and emblems
Someone (I cannot remember who or find my notes) told me that a good way to restore the badges and emblems is to use Tensor paints—-remove emblems and paint the inside. I do not recall how to paint the badges or to Mach the Dodge Emblem Red and Gold.
Any information greatly appreciated!
Posted 2018-07-22 3:37 PM (#567016 - in reply to #567013)
Subject: RE: 1956 Dodge Custom Royal Badges and emblems
500020002000500100100100100
Gbreslin - 2018-07-22 2:29 PM
Someone (I cannot remember who or find my notes) told me that a good way to restore the badges and emblems is to use Tensor paints—-remove emblems and paint the inside. I do not recall how to paint the badges or to Mach the Dodge Emblem Red and Gold. Any information greatly appreciated!
This?:
56D500boy - 2017-08-18 5:35 PM
I have just been doing this with my 56 Dodge Custom Royal. You want to do the back painting with model paint, e.g. Testors (or the like) *FIRST* (BEFORE you do any gluing). I used silver, red and black liquid and gold spray and a very fine brush. Leave the emblem in the chrome surround. Start by loosening the two screws that hold the emblem into the surround a bit and then push the two halves together and then tighten those two screws (to minimize the crack gap). Then do the back size painting, starting with the red black and silver. Paint up to the crack but NOT into it. Check for coverage by holding the emblem up to the light and noting where you need to add more paint. Keep going until you don't find any light coming through the red, black and silver areas. After that let them dry. Mask off the metal and then spray the back side with the gold spray paint, several light coats, check for light leakage and respray as needed. Only when you have finished with the painting and things have dried do you want to go for the clear epoxy or glue that you have chosen. You might want clear epoxy both on the back and front to fill in the crack. Don't use too much.
When the glue has set up sand the front side with very fine (e.g. 2000 grit wet and dry) sandpaper. Then polish with brand name plastic polish. Then wax.
I have done the back painting on one of my emblems (see below) and have a cracked one like yours that I am going to follow my steps above.
If you end up buying, DO NOT buy from George Laurie in Australia. I paid him in October and am STILL waiting for product.
This one had NO black and very little red before I started back painting:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-post.asp?action=rep...
Gbreslin
Posted 2018-07-22 5:07 PM (#567024 - in reply to #567016)
I should have known! Dave, I spent over an hour looking through all (and I mean ALL) of your e mails that I have saved and missed it!
I am going to try it and will probably have questions.
Thank you!
George
