drive shaft
swede59
Posted 2018-08-02 12:23 PM (#567634)
Subject: drive shaft
i installed a tourqueflite in my 59 plymouth is the bolt pattern on the parking brake different than the powerflite trans.
49pair
Posted 2018-08-02 9:38 PM (#567684 - in reply to #567634)
Subject: Re: drive shaft
I think my FSM shows they are. There are 2 different sizes on the front Detroit joint.
swede59
Posted 2018-08-04 9:37 AM (#567791 - in reply to #567634)
thanks for the info.
Posted 2018-08-04 1:59 PM (#567798 - in reply to #567634)
Subject: RE: drive shaft
20001000500100100252525
There are definitely two different bolt patterns used on the U-joint, don't know which ones are specific to the PF/TF. A tape measure will tell.
swede59
Posted 2018-08-06 11:23 AM (#567914 - in reply to #567634)
IS THE LENGTH OF THE DRIVE SHAFT DIFFERENT BETWEEN TF AND PF . CAN I USE PARKING BRAKE DRUM FROM A PF. OR DO I HAVE TO ORDER A NEW
DETROIT UNIVERSAL JOINT FOR THE TF. ANY INFO IS APPRECIATED.
THANKS
