60 dodge polara
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
grant4405
Posted 2018-08-13 8:58 AM (#568354)
Subject: 60 dodge polara
I have the data card from Chrysler on this convertible and have most the info I need but does anyone know if any of the fields tell what color the top was-black or white? It was originally a vermillion car.
Chrycoman
Posted 2018-08-14 5:12 AM (#568394 - in reply to #568354)
Subject: Re: 60 dodge polara
100050010010025
Across the top of the card there are a number of boxes with letters and numbers. Just beneath that is a row with headings (or footings). One of the boxes on that line should be "Paint", What are the letters / numbers in the box above "Paint"?
"P" is for Vemilion, So the car was Vermilion the paint code should be PP1
Column "33" is for the convertible top.
If the "1" is punched for that column the top was black.
If the "2" is punched, the top was white
Edited by Chrycoman 2018-08-14 5:18 AM
grant4405
Posted 2018-08-14 8:52 AM (#568400 - in reply to #568394)
Fantastic. you are a true genius. It is white. Much better than black.
