Help!.. idler Arm Mount failure
Beltran
Posted 2018-08-15 9:52 PM (#568502)
Subject: Help!.. idler Arm Mount failure
100050010010025
Anyone have a 55-56 Chrysler Idler Arm mount they are willing to part with?
Mine failed... during cruise week here in Michigan...
(IMG_4029.jpg)
(IMG_4030.jpg)
(IMG_4032.jpg)
Attachments IMG_4029.jpg (88KB - 77 downloads)
Attachments IMG_4030.jpg (55KB - 81 downloads)
Attachments IMG_4032.jpg (26KB - 78 downloads)
wildone770
Posted 2018-08-15 11:09 PM (#568504 - in reply to #568502)
Subject: RE: Help!.. idler Arm Mount failure
10010010025
HI I HAVE THIS IN AZ COMPLETE WITH IDLER. DON 602 6899414
Posted 2018-08-16 1:34 AM (#568511 - in reply to #568502)
Subject: Re: Help!.. idler Arm Mount failure
500050002000100025
Attention, something is not correct as for the steering linkage, which seems to caused a wiggling motion on the mount.
Check for bent steering linkage components first of all.
Once you get a replacement, mount the 2 lower bolts finger tight and leave the upper bolt loose. Have a helper turning the steering Wheel fully to the left and right while you check the eventual movement of the mount. You might have to add some shims for to find the position where the mount moves very little or not at all.
coronetx2
Posted 2018-08-16 5:21 AM (#568514 - in reply to #568502)
100252525
Hey I have one off a 56 dodge coronet if it will work
You can have it for free I live about 75 mile north of you
Let me know Phil
Posted 2018-08-16 9:48 AM (#568520 - in reply to #568514)
500020002000500100100100100
coronetx2 - 2018-08-16 5:21 AM
The 55-56 Plymouth and Dodge V8 idler arms had one bracket PN (1611 211) and the 55-56 Desoto and Chrysler V8 idler arms had another bracket PN (1556 306) so the Coronet bracket probably wouldn't work.
Edited by 56D500boy 2018-08-16 9:54 AM
(1955-56IdlerArmBracketPNs.jpg)
Attachments 1955-56IdlerArmBracketPNs.jpg (184KB - 78 downloads)
Beltran
Posted 2018-08-16 6:53 PM (#568538 - in reply to #568502)
100050010010025
My neighbor came through for me.. see pictures showing my prep work and his Tig welding...
(NSMJ0290.JPG)
(YGIM0151.JPG)
(IMG_4035.JPG)
Attachments NSMJ0290.JPG (201KB - 82 downloads)
Attachments YGIM0151.JPG (222KB - 80 downloads)
Attachments IMG_4035.JPG (231KB - 83 downloads)
Beltran
Posted 2018-08-16 6:55 PM (#568539 - in reply to #568502)
100050010010025
note the structural I-Beam enhancement to the part... we will not be failing again.
Beltran
Posted 2018-08-16 6:56 PM (#568540 - in reply to #568502)
100050010010025
I will look into your suggestions Wizard. Thanks.
Posted 2018-08-17 3:05 AM (#568550 - in reply to #568502)
500050002000100025
Good repair - it will hold, but I'd be looking for a new one
