HEADS, TRANSMISSIONS, ENGINE BLOCKS, CRANKSHAFTS
   Forward Look Swap Meet -> For Sale - PARTSMessage format
Kellyr68
Posted 2018-08-22 9:15 PM (#568882)
Subject: HEADS, TRANSMISSIONS, ENGINE BLOCKS, CRANKSHAFTS
New User
FOR SALE: #906 & #516 HEADS (4 SETS)
727 W/CHEETA REVERSE SHIFT PATTERN, MANUAL SHIFT VALVE BODY
727 W/CHEETA TRANS BRAKE VALVE BODY
(1) 383 ENGINE BLOCK
(3) 440 ENGINE BLOCKS
(1) 440 REGROUND CRANK .010" X .010"
(1) 440 CRANK NEW IN BOX
(1) 383 CRANK
LOTS OF VALVE COVERS AND ROCKER ARM ASSEMBLIES. SEVERAL SETS OF RODS & PISTONS. MILIDON OIL PAN FOR BIG BLOCK ENGINES AN TUBE CHASSIS CAR. A FEW RACING GAUGES, GASKETS AND ALUMINUM PARTS.
MANY MISCELLANEOUS ENGINE PARTS, ACCESSORIES, DAMPER, FACTORY BOLTS ETC.
CALL LARRY 636-856-6211
STOCKHEMI
Posted 2018-08-25 7:20 AM (#568996 - in reply to #568882)
Subject: RE: HEADS, TRANSMISSIONS, ENGINE BLOCKS, CRANKSHAFTS
LARRY
hi first off where are you ?
are the 440 blocks pre 70 and what condition
pistons and rods are these standard or oversize or forged
and the rockers arms are any sets mechanical
do you have any BB alloys manifolds ?
thanks
