1963 imperial carrier bearing
Fick4fun
Posted 2018-08-23 3:47 PM (#568914)
Subject: 1963 imperial carrier bearing
Does anybody know where or how to get a new carrier bearing for a 1963 imperial any help would great thanks
Shep
Posted 2018-08-23 5:33 PM (#568919 - in reply to #568914)
Subject: Re: 1963 imperial carrier bearing
20001000100
Center driveshaft support bearing? If so, Rockauto shows one.
Edited by Shep 2018-08-23 5:37 PM
Fick4fun
Posted 2018-08-23 6:30 PM (#568923 - in reply to #568914)
They have the bearing but it a wjole assembly.
Shep
Posted 2018-08-23 7:12 PM (#568928 - in reply to #568914)
20001000100
I don't think anyone makes that new. The rubber hanger rotted or broke?
Fick4fun
Posted 2018-08-23 7:23 PM (#568929 - in reply to #568914)
It is starting to shake prety bad of the line but if you start slow its fine but it is getting worse and it is the oringnal and sat for a long time. I think it is seperating id have yo crawl under and look closely
plymouth
Posted 2018-08-24 6:46 AM (#568943 - in reply to #568929)
2000100100
Damper Doctor rebuilds these. I had mine revulcanized and a new bearing installed.
Posted 2018-08-24 11:54 AM (#568952 - in reply to #568914)
Subject: RE: 1963 imperial carrier bearing
20001000100100
https://damperdoctor.com/index.php?route=information/information&inf...
Fick4fun
Posted 2018-08-24 7:04 PM (#568967 - in reply to #568914)
How long does it last after he fixes them.
plymouth
Posted 2018-08-24 8:37 PM (#568970 - in reply to #568967)
2000100100
Probably longer than 50 years.
Fick4fun
Posted 2018-08-24 10:37 PM (#568976 - in reply to #568914)
I think its needs ro be fixed its in 2 peices
Edited by Fick4fun 2018-08-24 10:39 PM
plymouth
Posted 2018-08-25 7:08 AM (#568995 - in reply to #568976)
2000100100
Yep, that's a problem. Damper Doctor can fix it. They are pricey, but the quality and turn around time is fantastic. If you're driving this car quite a bit, I'd suggest pulling the crank pulley( held on by 5 bolts I believe, and have them revulcanize that rubber too. It happened to me. First was the driveshaft support, then about two weeks later the pulley failed.
Edited by plymouth 2018-08-25 7:09 AM
Coronet_Jeff
Posted 2018-11-08 7:46 AM (#573163 - in reply to #568914)
They are reproduced and available on eBay if you don't want to wait for the turn around.
StillOutThere
Posted 2018-11-08 10:18 AM (#573168 - in reply to #568914)
2000500100100100100252525
Then and Now has been making these for a couple of years. Have one in my '56 Imperial. Perfect, reasonable. Not on the net page but call them. http://www.then-now-auto.com/nors-vulcanized-motor-mounts-rubber-pr...
