Avoiding a $1400 steering wheel renewal - a cheap@ss alternative Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | When I got my 56 Dodge in Sept. 2016 (coming up 2 years), the two-tone plastic steering wheel in the car was literally falling apart. I couldn't drive like that so I bought a better two-tone plastic wheel. It was still bad but at least all the bits were still on it. To create a useable wheel from that one, I painted the upper part with several coats of PlastiDip to hold the bits together. This was followed by gloss white Tremclad on the top and a Duplicolour Chrysler product "Electric Blue" paint. That made for a useable steering wheel. I also inquired about the cost of s professionally redone steering wheel. The answer was US$1400 for a beautifully recast wheel. Too rich for my budget. So I decided to look for a solid rubber steering wheel to fix because I found out that they typically cracked less. I bought one from French Lake Auto Parts (FLAP) in Minnesota with the plan of fixing and painting it some day. That day finally came last week. The first thing was to acquire some JB Weld brand "PlasticWeld" epoxy putty (two part - you cut it and mix it together). Before I could put the PlasticWeld on, I had to open up the few cracks with my Dremel. I used a fiber cut-off wheel for that task. Then I cut about 1.5" of the epoxy putty and kneaded it until it was a consistent uniform colour. That was a lot of work - took about 10 minutes. Good news there was still plenty of working time. I pushed the putty into the cracks with my fingers and an old flat blade screw driver. I tried not to miss anything but I knew that if I did, I could fix the problem with either more putty or spot putty. I let the epoxy cure over night and then sanded it off with my Dremel and fibre disc (One of my favourite all round tools right now). Once the epoxy was sanded off and the wheel wiped off, I could see small bits that I missed and places where I had gotten careless with the Dremel and had made some small cuts. So those bits got Spot Putty. When the Spot Putty was dry, I sanded it off with 100 grit and then looked for more imperfections. Then one more round of Spot putty and sanding. When I was reasonably happy, I sanded the entire wheel (by hand) with 220 grit. Then I wiped it down and sprayed on high build Duplicolour primer. This brought out more imperfections that I had missed. So another round of Spot putty, sanding and primer. After quick sand with 400 grit, I sprayed the top half of the steering wheel with Duplicolour Wimbelton white (which is a close match to the Sapphire White on my car's roof). (So what it is a Ford colour - it works). After several coats of the white and a thorough overnight drying, I masked off the white and prepped for painting the bottom blue. I used 3M Painters blue at the interface because I knew it would create a crisp, no bleed line. Then I sprayed several coats of Duplicolour 2416 Electric Blue - because I had it and it looks good. Quite sparkly. As you can see from the photos below, the result is better than what I had. Not even close to a proper $1400 re-cast but my car is never going to warrant that kind of attention or a $10000 paint job. This cost me $100 for the rubber wheel, $10 for the primer and $10 for the paint. Say $135 all in. Next step - figure out what is up with the horn slip ring. I didn't even notice the issue until I saw the photos that I put together for this post. Hope this helps somebody in the future. Edited by 56D500boy 2018-08-28 8:53 PM (56DodgeCustomRoyalSteeringWheelRenewal_1_TheOriginalSteeringWheelThatCameWithMyCar.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_2_ASecondInterimSteeringWheelThatWasPlastiDippedAndPainted.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_3_FullRubberWheelFromFrenchLakeAutoParts.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_4_FullRubberWheelFromFrenchLakeAutoParts_ExampleCracks.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_5_FullRubberWheelFromFrenchLakeAutoParts_OpeningCracksWithDremel.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_6_FullRubberWheelFromFrenchLakeAutoParts_FillingCracksWithPlasticWeld_Back.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_7_FullRubberWheelFromFrenchLakeAutoParts_FillingCracksWithPlasticWeld_Front.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_8_FullRubberWheelFromFrenchLakeAutoParts_RemovingEpoxyWithDremel_Back.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_9_FullRubberWheelFromFrenchLakeAutoParts_UsingSpotPuttyOnEpoxy_Front.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_9_FullRubberWheelFromFrenchLakeAutoParts_UsingSpotPuttyOnEpoxy_Back.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_10_FullRubberWheelFromFrenchLakeAutoParts_SandingOffSpotPuttyOnEpoxy_Back.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_11_FullRubberWheelFromFrenchLakeAutoParts_PaintingWimbeltonWhiteOverPrimer.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_12_FullRubberWheelFromFrenchLakeAutoParts_PaintingWimbeltonWhiteOverPrimer.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_13_FullRubberWheelFromFrenchLakeAutoParts_PaintingBottomWithElectricBluePaint.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_14_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct.jpg) (56DodgeCustomRoyalSteeringWheelRenewal_15_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct_Detail.jpg) Attachments ---------------- 56DodgeCustomRoyalSteeringWheelRenewal_1_TheOriginalSteeringWheelThatCameWithMyCar.jpg (189KB - 367 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_2_ASecondInterimSteeringWheelThatWasPlastiDippedAndPainted.jpg (220KB - 357 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_3_FullRubberWheelFromFrenchLakeAutoParts.jpg (193KB - 371 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_4_FullRubberWheelFromFrenchLakeAutoParts_ExampleCracks.jpg (185KB - 368 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_5_FullRubberWheelFromFrenchLakeAutoParts_OpeningCracksWithDremel.jpg (158KB - 368 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_6_FullRubberWheelFromFrenchLakeAutoParts_FillingCracksWithPlasticWeld_Back.jpg (185KB - 363 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_7_FullRubberWheelFromFrenchLakeAutoParts_FillingCracksWithPlasticWeld_Front.jpg (206KB - 371 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_8_FullRubberWheelFromFrenchLakeAutoParts_RemovingEpoxyWithDremel_Back.jpg (217KB - 356 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_9_FullRubberWheelFromFrenchLakeAutoParts_UsingSpotPuttyOnEpoxy_Front.jpg (176KB - 376 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_9_FullRubberWheelFromFrenchLakeAutoParts_UsingSpotPuttyOnEpoxy_Back.jpg (206KB - 363 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_10_FullRubberWheelFromFrenchLakeAutoParts_SandingOffSpotPuttyOnEpoxy_Back.jpg (202KB - 372 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_11_FullRubberWheelFromFrenchLakeAutoParts_PaintingWimbeltonWhiteOverPrimer.jpg (172KB - 363 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_12_FullRubberWheelFromFrenchLakeAutoParts_PaintingWimbeltonWhiteOverPrimer.jpg (202KB - 374 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_13_FullRubberWheelFromFrenchLakeAutoParts_PaintingBottomWithElectricBluePaint.jpg (243KB - 358 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_14_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct.jpg (199KB - 368 downloads) 56DodgeCustomRoyalSteeringWheelRenewal_15_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct_Detail.jpg (174KB - 372 downloads) | ||
Expert 5K+ Posts: 5006 | Looks good, i did that also. Fair amount of work but worth it... You have to start with a reasonable one though. | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | I did the same thing but used the POR-15 epoxy. $25 Ebay wheel and a couple of hours work and I was happy. | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | Nice work. Now sell it for $1400? | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | BigBlockMopar - 2018-08-29 1:59 PM Nice work. Now sell it for $1400? LOL. No. Special this week only, $699. Kidding. | ||
Stroller |
Extreme Veteran Posts: 371 | I love JB Weld | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | Very nice! | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | You are good! | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | . Well, it only took me like 2.5 years to get the "new" steering wheel installed. The impetus was I had to remove the interim steering wheel to investigate a signal light switch issue and there was no reason not to install the French Lake all rubber steering wheel when I was completing that fix. Signal light switch investigations: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75266&... The "new" steering wheel, installed (looks pretty good, feels great with no cracks anymore) (Remember the white is Ford "Wimbledon White" which is a little yellow, which in this application is a good thing): Edited by 56D500boy 2021-02-11 9:09 PM (56DodgeCustomRoyalSteeringWheelRenewal_14_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct_Installed.jpg) Attachments ---------------- 56DodgeCustomRoyalSteeringWheelRenewal_14_FullRubberWheelFromFrenchLakeAutoParts_FinalProduct_Installed.jpg (171KB - 233 downloads) | ||
22mafeja |
Elite Veteran Posts: 653 Location: Finland | The dash looks really sharp Dave. What are the two additional meters sitting on the steering column? Is your ashtray missing? I might have one if you need.. | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | 22mafeja - 2021-02-12 4:52 AM The dash looks really sharp Dave. What are the two additional meters sitting on the steering column? Is your ashtray missing? I might have one if you need.. Thanks Ralf. I don't know why it took me over two years to install that "new" steering wheel (I guess the interim, cracked but painted, steering wheel was good enough - until it wasn't) I have an ashtray. I had removed it to try to figure out how to disassemble it so I could paint the non-chrome middle bit and then apply a new ASH TRAY decal that I bought years ago. Still trying to figure out what to do on that one. The ashtray was basically welded and riveted together with the center knob being a big rivet (no nuts involved). The gauges are the custom ones that I "designed" (using Autometer's software) and Autometer made for me. Volt meter on the left (I was having generator and starter issues at the time) and Tach on the right (I don't want to push the engine over 4400 RPM (fat chance of that)). The pod is one that I constructed (with welding aid from my neighbour) from a section of dash that I bought from John F. at Big M and a new (NOS) gauge bezel (perfect chrome rings and plastic), as documented here: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67964&... These: | ||
big m |
Expert 5K+ Posts: 7806 Location: Williams California | Nice job on the steering wheel, Dave! I've used JB weld on some, and it's held up pretty well. ---John | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | IMHO, there should be a small gap (1/8"?) between the upper and lower portions of the wheel to allow for expansion/contraction of the metal core. Not that it helped much with the poor quality plastic that they used back then. Ron | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | ronbo97 - 2021-02-15 10:59 AM IMHO, there should be a small gap (1/8"?) between the upper and lower portions of the wheel to allow for expansion/contraction of the metal core. Not that it helped much with the poor quality plastic that they used back then. Time will tell. It certainly didn't save even the best two-tone plastic steering wheels from cracking. The one that I used this time is a "rubber" one, and if there was a gap, I filled it. Photos of OE two-tone plastic wheel photos that I saved for reference: Edited by 56D500boy 2021-02-15 2:59 PM (55DodgeTwoToneSteeringWheel.jpg) (OE55_56DodgeTwoToneSteeringWheelShowingAgedColours_small.jpg) Attachments ---------------- 55DodgeTwoToneSteeringWheel.jpg (133KB - 228 downloads) OE55_56DodgeTwoToneSteeringWheelShowingAgedColours_small.jpg (208KB - 219 downloads) | ||
rockerarm |
Elite Veteran Posts: 873 Location: ALABAMA, HEART OF DIXIE | Beautiful.... Nice work. | ||
