Steering Wheel Boss 1960 New Yorker Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
1coolbanana |
Veteran Posts: 267 Location: Sydney | Id like to get my original steering wheel restored but it will take up to 12 weeks. In the meantime, Id like to fit a temporary one as I drive the car quite a bit. I cant seem to find anywhere that lists a fitment or availability to suit this. Can anyone help with some info regarding an aftermarket wheel and boss kit or compatibility with something else? Cheers and TIA | ||
Expert 5K+ Posts: 9666 Location: So. Cal | I am in a similar situation, but I ended up picking up a cheap wheel from a '62 Newport. It was easier than looking for an adapter. | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | That's one of the reason why a person always should have multiple car-projects lingering around. Spare parts rule! I've seen folks drive around with a vice-grip for steering | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Probably better off buying one in the states and getting it restored there or getting one that's done. Restoration costs on these mopar wheels is pricey. If you were in Perth, I could lend you a wheel from a 58 Plymouth (I think) but might be from a royal, but no horn stuff I do have 2 aero wheels, but only one set of horn components and 1 std 60 Plymouth wheel that's rough, but for std steering and the remnants of a 60 dodge wheel The wheels for standard and power are different as the horn wire for the std one goes up the centre of the steering shaft, where the power one has a horn contact ring. Be prepared for big coin though, the fancy wheels will cost over a grand (especially by the time it gets here) george laurie had some wheels for sale ages ago | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | I was actually going to use https://pearlcraft.com.au But I just found out they cant do a resto on the clear wheels like mine. Also, would be a grand to get it done in 2 tone. Ill have to find another alternative or just go with aftermarket if I can find one to fit. What are the Aero wheels you are referring to? What aftermarket wheels are available to suit mine? Seems awfully hard to track something down that suitable. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Lucite steering wheel restauration COSTs roundabout SEK 5000 (AUD 800) in Sweden. Since this is a time consuming work (also depending on current order status), be prepared to wait at least 3 months. There is actually no after market steering wheels that would go together with the AstraDome. | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Is that cost for a re-casting of clear steering wheels or just epoxy repair? | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | The cost covers full removal of all old plastic, rechroming of the steering wheel, recasting in all clear plastic and painting of the colored section. The result is very durable and looks totally great. (IMG_3531-rez.jpg) Attachments ---------------- IMG_3531-rez.jpg (116KB - 252 downloads) | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | That looks fantastic but waiting time and price wise its a little too much Im quite stunned that there is nothing aftermarket that will work with the astrodome. If I could find a suitable boss, I could possibly use it to machine an adapter......maybe??? | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Don't get me wrong, of course there are bosses that will fit the steering shaft, but they will never fit designwise. If you need a temporary steering wheel, then Grant might be a choise - one of these will fit http://www.grantproducts.com/products/browse/installation-kits/auto... but really, is it impossible to indicate MoPar and year in the description?? | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Aero wheel is a general term for the clear wheels Here is a link to someone that re casts them http://qualityrestorations.com/plymouth-steering-wheels/ I got mine from George Laurie. Its a NOS one and was cheap compared to re casting but wasn't cheap in the scheme of things Before I bought the NOS one, I got a "repaired one that has since cracked up without any actual use and will probably just be a wall hanger as it still cost me a grand (Aero wheel 002s.JPG) Attachments ---------------- Aero wheel 002s.JPG (76KB - 250 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Correction, the aero wheels are the squarish steering wheels which could have parts made of Lucite, hence clear, but not necessarily. A clear steering wheel is referred to as a Lucite steering Wheel So, in the photo above there are two aero steering wheels, one Lucite and one normal | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Ok, thanks for the info. I would love this in a 14-15" version :-) Edited by 1coolbanana 2018-09-20 5:42 AM | ||
Expert 5K+ Posts: 9666 Location: So. Cal | What is the name of the company in Sweden, wizard? Recasting in the US is more than 3X that amount. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | GITTANS RATTAR The guys name Magnus Stade stade.b@telia.com Below some photos n Dieter's steering wheel (IMG_2141-rez.jpg) (IMG_2145-rez.jpg) Attachments ---------------- IMG_2141-rez.jpg (267KB - 244 downloads) IMG_2145-rez.jpg (255KB - 239 downloads) | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Thanks Sven! | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | The wheel on the right in my pic above is a clear wheel, its been painted It looked pretty good when I first got it, but if you look closely at the white sections, you can see where it started to crack Your wheel isn't that bad for a driver, as I said above, be better to get another wheel and get that one fixed. The aero wheels as a core (stuffed) sell for around US$500, but I don't think yours is quite that bad Wizard might know of a core available to get done in Sweden As mentioned, the US restorer is much more pricey, but he does do the recast using clear and coloured plastics, not just clear and paint | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Can anyone tell me what the compatible models and years would be that will fit? If I can find an alternative to use to be modified/restored or to use temporarily while mine is being done. | ||
56300B |
Extreme Veteran Posts: 480 Location: The Great Northwest | It certainly looks as though a 61 New Yorker wheel would work for you...…. (Steering Wheel R.JPG) Attachments ---------------- Steering Wheel R.JPG (211KB - 231 downloads) | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Thanks for that. Any other Chrysler models that fit? New Yorker steering wheels are non existent or worth crazy money. Like for example, the 62 Newport mentioned above by Powerflite... | ||
Expert 5K+ Posts: 9666 Location: So. Cal | This is the wrong color for me, but otherwise I would just buy it and bolt it on. It's for a '60 and in decent shape. I'm not sure where the cutoff is for interchangeability, but it works at least to '62, but probably much later than that as well. https://www.ebay.com/itm/202447298555?ul_noapp=true | ||
