still looking for a brake pedal rod
udoittwo
Posted 2018-09-20 6:52 AM (#570434)
Subject: still looking for a brake pedal rod
1000100100
I THINK I can use a non-power brake rod also but would prefer a power brake rod. I need the rod that connects to the pedal itself.
Thanks for any help,
Karl.
jboymechanic
Posted 2018-09-20 10:03 AM (#570443 - in reply to #570434)
Subject: Re: still looking for a brake pedal rod
1000100100100100252525
What master cylinder are you planning to use? I've been through this on my '60 Plymouth, updated to 4 wheel disc and dual reservoir master. I stayed with manual brakes though. I had a spare push rod from my '57 Imperial that I modified and used on the Plymouth. You can make one pretty easily too, get a heim joint and some threaded rod.
b5rt
Posted 2018-09-20 9:24 PM (#570480 - in reply to #570434)
200010010010010025
My car had a non power rod in it. I've not been able to find a proper original power adjustable rod so with help from Mark on here, I've purchased this one. It appears that it will work correctly, but haven't installed yet. https://www.summitracing.com/parts/rsd-rc14
wildone770
Posted 2018-09-20 11:44 PM (#570487 - in reply to #570434)
Subject: RE: still looking for a brake pedal rod
1001002525
HI I HAVE THE CORRECT ROD FOR POWER BRAKE FOR 1960. DON 602 6899414 THANKS
udoittwo
Posted 2018-10-03 6:55 AM (#571091 - in reply to #570434)
1000100100
Thanks for the offers but I believe I found one. IF it is not the one I am looking for, I'll get back to all of you.
Thanks again,
Karl.
b5rt
Posted 2018-10-03 10:22 PM (#571122 - in reply to #570434)
200010010010010025
As an update, I installed the RC14 from Summit and it fit perfect. Made a couple adjustments and all is good now.
