A Poly years
ttotired
Posted 2018-09-21 7:38 AM (#570499)
Subject: A Poly years
50002000100010010010010025
What were the block changes for the A poly?
I have a 60 block and a bloke with a 62 wants an engine
Pretty sure they are the same block and crank ect, but thought I should ask
grunau
Posted 2018-09-21 8:21 AM (#570502 - in reply to #570499)
Subject: Re: A Poly years
10010010010025
Hi
The block is the same but the crankshaft flange was changed after 1961 with the discontinuation of the cast Iron Torqueflite transmission as the Aluminum A-727 Torqueflite was introduced in 1962.
58coupe
Posted 2018-09-21 10:05 AM (#570503 - in reply to #570499)
100050010010025
Actually, the bolt pattern also changed on the A poly between 61 and older vs. 62-66, not just the crank.
Mopar1
Posted 2018-09-21 11:12 AM (#570505 - in reply to #570503)
2000100025
He would have to use a 392 to (whatever Tranny) adaptor.
jboymechanic
Posted 2018-09-21 1:57 PM (#570509 - in reply to #570503)
2000100252525
58coupe - 2018-09-21 9:05 AM
What bolt pattern?
60 dart
Posted 2018-09-21 4:57 PM (#570522 - in reply to #570499)
50002000100050010010010010025
i borrowed this from and old thread ------------------------------------------------------------later
61 was the last of the 8 bolt cranks, also the bellhousing dowel pins changed locations after 61..
62 and newer polys also had a different block casting on the lower right side of the block at the bellhousing (not as long) which does not allow use of the bottom bolt on that side .
ttotired
Posted 2018-09-21 6:38 PM (#570531 - in reply to #570499)
So my engine isn't any good for him
Thanks I thought the change was 63
