57 Imperial - hood insulation install
imperial2100
Posted 2018-10-18 9:58 AM (#571900)
Subject: 57 Imperial - hood insulation install
1002525
So my 57 does not have any insulation under the hood. I ordered some replacement stuff but I don't see anything that's going to hold it in. Am I supposed to slather on some rubber cement to hold this stuff or should it just wedge in and hold itself? Or are there some clips that I'm missing that should hold it in?
Posted 2018-10-18 10:39 AM (#571902 - in reply to #571900)
Subject: Re: 57 Imperial - hood insulation install
5000
I think it was glued.... maybe use some Velcro pads?
rebel
Posted 2018-10-18 11:12 AM (#571905 - in reply to #571902)
It was glued. Don't just use rubber cement or regular contact adhesive since it won't stand up to the heat. I used Weldwood Landau Top and Trim HHR (high heat resistant) contact adhesive. You "might" find something that is rated for high heat in a rattle can? It's also much easier to install if the hood is not on the car.
Good luck!
Bob
hemidenis
Posted 2018-10-18 2:08 PM (#571914 - in reply to #571900)
20001000500100100100252525
This may sound strange, but I never saw any padding under the Imperial hood.
imperial2100
Posted 2018-10-18 2:13 PM (#571916 - in reply to #571914)
1002525
Mine had some at some point, as I can see the pattern where it was pressed or glued against the underside of the hood. That's why I ordered some, I assumed it was missing.
Phil_the_frenchie
Posted 2018-10-18 3:52 PM (#571926 - in reply to #571900)
500100100100100
I agree, no padding but something was present, i've some (thin) material under the renforcements of the hood. I'll try to put a pic tomorrow.
When i restored the car i put ... nothing !
