  Location: Australia | Can anyone supply a picture of the jack in the trunk on 57 -59 imperials. I want to see how it is installed and secured in the trunk.
Chris Wardle |
   Location: Under the X in Texas | I expect this is the same as '57-59 Chrysler and DeSoto. They have a tin hook spot welded to the right side floor just inside the vertical trunk panel. The cars then came with a silver cad plated threaded hook and strap bracket to hold down jack and handle. 300 Club has perfect repro of the hook and bracket with wing nut.
 Location: Whetstone, Arizona | My 57 Desoto owners manual showed the jack shaft is stowed inside the trunk latch housing |
      Location: New Castle PA | If StillOutThere is right that it's the same as '57 DeSoto, it would be like these pictures.
(jack_detail2.JPG)
(jack_holddown.jpg)
Attachments ----------------
The '59 is on the opposite side from the '57-'58's, at least in the DeSoto. I would assume at least the Chrysler is consistent with the DeSoto, but I don't know about the Imperial. |
  Location: Australia | The Imperial goes on the Left inner side of the trunk unlike desoto. It has all the mountings but need to see a pic of it all tied down. |
