WTB: 1962 Chrysler A727 Aluminum case TorqueFlite Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I am gathering parts for a Powerflite to Torqueflite conversion for my 56 Dodge D500. I was thinking that the air-cooled 57 Torqueflite would be the easiest choice for me. However, I have been in contact with someone who has made the conversion on his 56 D500 and he is strongly suggesting that I should go aluminum case A727 from a 1962 Chrysler (because of the drum eBrake). Like the photos attached (that I found in an old for sale thread). Any leads will be appreciated.
Edited by 56D500boy 2018-12-19 1:17 AM (DSC00304.JPG) (DSC00309.JPG) (DSC00311.JPG) Attachments ---------------- DSC00304.JPG (152KB - 129 downloads) DSC00309.JPG (148KB - 128 downloads) DSC00311.JPG (147KB - 129 downloads) | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | The 57 has the drum e-brake. | ||
matador440 |
Elite Veteran Posts: 690 Location: BELTSVILLE, MARYLAND 20705 | I don't think that is going to interchange well. The 56 motor has a longer crankshaft and a different way of bolting up the torque converter. The 62 trans uses a separate flex plate that the torque converter bolts to. The 56 has a torque converter with the starter teeth all in one piece. The 61 trans should work a lot better as its the same design as the 56. If your friend got a 62 trans to work with a 56 motor Id like to know how he did it.. Edited by matador440 2018-12-19 8:28 AM | ||
tallzag |
Regular Posts: 53 | I have a couple, near Olympia, WA. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | matador440 - 2018-12-19 8:23 AM I don't think that is going to interchange well. The 56 motor has a longer crankshaft and a different way of bolting up the torque converter. The 62 trans uses a separate flex plate that the torque converter bolts to. The 56 has a torque converter with the starter teeth all in one piece. The 61 trans should work a lot better as its the same design as the 56. If your friend got a 62 trans to work with a 56 motor Id like to know how he did it.. The "friend" is Dave H**stad from Minnesota who had his own D500 website where he documented his many modifications to his 56 D500. He sent me his 8 page single-spaced WORD doc and a ton of photos on how to do the transmission swap. The transmission core he used was a 1962 A 727 (for an A series small block engine e.g. (318 poly)). He says that an A 727 from 62-65 would work. The tail section with the drum eBrake came from a 62 B727 (i.e. from a big block, 361, 383, 413). He used an after market 24 spline/10 bolt torque converter. He also used a TR Waters adapter plate: https://www.trwaters.com/product/early-hemi-transmission-adapters/ In discussions with Dave yesterday (by email) he suggested that I could reuse my PowerFlite Torque converter, etc. if I wasn't going to be drag racing the old girl. But really I have no clue on this swap so I am taking Dave at his word. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | tallzag - 2018-12-19 10:58 AM I have a couple, near Olympia, WA. Tom: I emailed you at Rocket Resto. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | NO MORE CALLS FOLKS. I've decided to go 57 or 58 Cast-iron torqueflite. Fewer issues to do the swap. Maybe not as good but it will be fine for my needs. Thanks to those who responded. Edited by 56D500boy 2019-01-28 8:01 PM | ||
