Rechroming vent window assembly’s.
57DODGECONV
Posted 2019-01-13 3:23 PM (#576721)
Subject: Rechroming vent window assembly’s.
5001001001002525
I am in the process of rechroming my 58 Mayfair Convertible vent window assembly’s.I have drilled out the rivets and taken them apart .What is everyone using to reassemble them in place of the original rivets.Thanks in advance.
Darryl T
Posted 2019-01-18 1:18 PM (#576995 - in reply to #576721)
Subject: Re: Rechroming vent window assembly’s.
10010010010025
I used s/s rivets in various lengths from Jay-Cee Sales & Rivet, Inc. (www.rivetsinstock.com). They have setting tools but I just made one out of an old punch. Balancing the assembly by myself while setting the rivets was fun...
sermey
Posted 2019-01-18 8:53 PM (#577019 - in reply to #576721)
Subject: RE: Rechroming vent window assembly’s.
1000100100
If your window rubber is bad, you can proceed as I did 15 years ago. As positioners I used matches. Need one week to dry through, then cut borders softly. Windows for ever centered and sealed. And use only stainless rivets. Good luck David!  - SERGE -
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&start=38
Edited by sermey 2019-01-18 9:33 PM
57DODGECONV
Posted 2019-01-19 3:52 PM (#577055 - in reply to #576721)
5001001001002525
Thanks both of you for the reply ,my Gaskets are still Good but the Die cast needs plating .I Have them all apart just need to figure out the rivets .
57DODGECONV
Posted 2019-01-19 3:58 PM (#577056 - in reply to #576721)
5001001001002525
Darryl ,off hand do you remember the size of the rivets you used? Thanks.
Darryl T
Posted 2019-01-20 2:33 PM (#577121 - in reply to #577056)
10010010010025
They are 5/32" diameter, in lengths of 7/32, 9/32, 3/8, and 7/16. The 7/32 were truss head, the rest oval head. They sell them in minimum quantities of 100 ea. Obviously I had a few left over, so if interested PM me your address and quantity needed and I'll fix you up, no charge. How's that for a deal?
57DODGECONV
Posted 2019-01-21 1:54 PM (#577171 - in reply to #576721)
5001001001002525
PM sent.
