door removal
582drht
Posted 2019-01-17 10:53 PM (#576964)
Subject: door removal
Just about to remove the doors on the 58 HT the hinge bolts seem easy to get to but the strap that prevents the door from travelling further than Desoto wanted seems that the attachments are spot weld in place in the door and the body frame. There is a pin on the frame side, I guess we cut, grind and remove pin?
Any one done this before? ( dumb question I know )
Thanks
Posted 2019-01-18 1:56 AM (#576972 - in reply to #576964)
Subject: Re: door removal
5000
yes grind the top off, no choice. Carfully
Posted 2019-01-18 2:22 AM (#576975 - in reply to #576964)
50002000200050010025
Yeah, it's a pain in the neck. I wish there were another, better way. You also will likely have to pry up on the openings a little to get it out. I had to at least. Not sure what I am going to use to put it back together yet.
57DODGECONV
Posted 2019-01-18 10:48 AM (#576991 - in reply to #576964)
5001001001002525
There is a seller on EBay that sells a 2 piece rivet Looking screw that is Designed to replace this and looks very close to original.
582drht
Posted 2019-01-19 3:38 PM (#577053 - in reply to #576964)
Thanks guys, well I gently ground it out with a battery grinder and then with a punch from the top and copper mallet got it to slide down and out easily. But I tell you what removing the glass and all internals is a nightmare!!! but done now.
Time to do the other door, trunk lid and send them off for dipping to remove all rust and gunk. The hood went in last week and should be back next week. AU$330 just to dip the hood. Then its windscreens. and every thing else and the body gets dipped as well. When it comes back it will go on the rotisserie I welded up and then new rocker panels and whatever else we find needs repairing.
582drht
Posted 2019-01-19 3:44 PM (#577054 - in reply to #576991)
Any chance that you know the listing heading for theose pins?
57DODGECONV
Posted 2019-01-19 4:03 PM (#577057 - in reply to #576964)
5001001001002525
If you do s EBay search for 1950s 1960s Mopar Door Limiting arm or Door check strap- river kit you will see it.
Old Ray
Posted 2019-01-19 6:45 PM (#577074 - in reply to #577057)
500
https://www.ebay.ca/itm/1950s-1960s-Mopar-Door-Limiting-Arm-or-Door-Check-Strap-Rivet-Kit/351426494972?hash=item51d2a6c1fc:g:O-kAAOxy02dRgMvQ:rk:1:pf:0&vxp=mtr
Posted 2019-01-19 10:44 PM (#577084 - in reply to #577053)
5000
582drht - 2019-01-19 3:38 PM Thanks guys, t I tell you what removing the glass and all internals is a nightmare!!! but done now.
everythings on youtube
https://www.youtube.com/watch?v=sorlPtAIlSs
Edited by mikes2nd 2019-01-19 10:45 PM
582drht
Posted 2019-01-20 4:05 PM (#577125 - in reply to #577074)
Thanks Old Ray.
582drht
Posted 2019-01-20 4:08 PM (#577126 - in reply to #577084)
Thanks Mike
Old Ray
Posted 2019-01-20 7:53 PM (#577136 - in reply to #576964)
Subject: RE: door removal
500
After looking at those on eBay, I think a Threaded Rivet Nut with the right OD, and a screw with a flat washer would work ?
(51FHiIivfCL__SL1000_.jpg)
Attachments 51FHiIivfCL__SL1000_.jpg (46KB - 155 downloads)
Posted 2019-01-20 8:48 PM (#577139 - in reply to #576964)
You can also purchase 10 parts of the same thing as shown in the ebay add for the same price from McMaster.com, but in stainless. Steel versions are a little cheaper. They are called Binding Barrels.
Posted 2019-01-20 10:01 PM (#577143 - in reply to #576964)
5000
yeah everyone finding a sucker on ebay Ill take the stainless versions. Just buy 10 because we all have more than one FWL car
they carry them at the local hardware store. I would thread lock this one I think
https://www.mcmaster.com/rivets
Edited by mikes2nd 2019-01-20 10:04 PM
