60 Windsor Steering Box Rebuild
Cmangeot
Posted 2019-01-28 9:59 AM (#577500)
Subject: 60 Windsor Steering Box Rebuild
50025
Hi,
Same question as on the front end. Will the kit from Rock Auto work to change out gaskets on my steering box? Im getting a leak from the top. I am sure the seal is bad.
Thanks in advance!
Posted 2019-01-28 10:03 AM (#577502 - in reply to #577500)
Subject: Re: 60 Windsor Steering Box Rebuild
500050002000100025
Yes, I have renovated several steering gears with kits from RockAuto. There are normally some seals/gaskets that you don't need - I guess that is for a larger cover of year models.
