60/61 sill plates
rockerarm
Posted 2019-03-03 2:44 PM (#578821)
Subject: 60/61 sill plates
50010025
I need both left and right sill plates for a 2 door 1960 or 61 Plymouth or dodge.
Thanks, Will.
Space Trukin Wagon
Posted 2019-03-05 12:07 AM (#578885 - in reply to #578821)
Subject: RE: 60/61 sill plates
1002525
In case you’re not aware the door sill plates on 1960-61 Plymouth & Dodge cars have different pattern / design stampings.
Yes they will interchange but are specific to the car line.
Have to check but I may have a set for 1960-61 Dodge.
rockerarm
Posted 2019-03-05 10:54 AM (#578901 - in reply to #578885)
50010025
Space Trukin Wagon - 2019-03-05 12:07 AM In case you’re not aware the door sill plates on 1960-61 Plymouth & Dodge cars have different pattern / design stampings. Yes they will interchange but are specific to the car line. Have to check but I may have a set for 1960-61 Dodge.
Thanks for the response. I am aware of the differences but need a nice pair to restore and use on my 61 Fury until the correct ones come along.
If you have a set from a Dodge I'd love to see them.
Thanks.
Will.
ttotired
Posted 2019-03-06 2:43 AM (#578925 - in reply to #578821)
Subject: Re: 60/61 sill plates
500020001000100100252525
From my experience with 60 dodge and Plymouth sills, you can use 4 door on 2door (cut them down)
I also found that the steel used in the repo ones is thinner than factory ones, so be aware of that
On my dodge, I replaced both sides full length, with the Plymouth, I only cut out what I needed to and welded that in
It turned out much better and easier
You will also find braces in the sills that will need attention.
I have left over sections, but being here in Aus, I think shipping would be to pricey.
I got mine off ebay, but black car would be a soarce, but I have noticed that the repair sections for these cars are getting rarer
It might be worth cutting out a section and finding a sheetmetal works to make a length for you
Posted 2019-03-06 8:05 AM (#578931 - in reply to #578925)
5000500100100252525
ttotired - 2019-03-06 2:43 AM
"cut them down"...."weld".... "steel"... ? Sill plates = aluminum trim that bolts to the rockers under the doors.
ttotired
Posted 2019-03-07 1:34 AM (#578979 - in reply to #578821)
My bad, We call rockers sills here
