57 Dodge Royal 325 Oil Filter Conversion Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ictfatboy |
Member Posts: 17 | Does anyone know if there is an "easy" conversion kit to get rid of the canister type filter and replace with a spin on cartridge filter on a 57 325 V8? That canister is in such a difficult spot and inevitably I do not seem to get it tight enough the first time or the gasket slips and I end up spraying oil all over even when I think I have done it correctly. I want to keep the car original as possible but changing that to a spin on filter would sure make PM much simpler! | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | Here's a great link that you might want to investigate. What you are looking for is there on page 1. http://www.hothemiheads.com/dodge/index.html | ||
Expert Posts: 3777 Location: NorCal | I installed the Hothemiheads 30° adapter on my '57 Dodge 325. Makes filter changes a snap. Edited by 57chizler 2019-04-03 12:27 PM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Actual name is Hot Heads. I use the up angle one on my 331 also | ||
Expert 5K+ Posts: 5006 | I am not sure about draining the oil from the filter ever time you shut it off? I guess it shouldn't matter... | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | Mopar1 - 2019-04-03 6:56 PM Actual name is Hot Heads. Agree but yet they themselves use hothemiheads in their URL. Go figure. (HotHeadsDodgeHomePageScreenCapture.jpg) Attachments ---------------- HotHeadsDodgeHomePageScreenCapture.jpg (146KB - 170 downloads) | ||
Expert 5K+ Posts: 9666 Location: So. Cal | It's probably because hotheads.com was being used by someone else already. I just looked and it is currently some kind of fashion site. | ||
Expert Posts: 3777 Location: NorCal | mikes2nd - 2019-04-04 10:10 AM I am not sure about draining the oil from the filter ever time you shut it off? I guess it shouldn't matter... There is a check valve in the filter that prevents drain back. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 57chizler - 2019-04-04 5:06 PM plus the anti-drain back check ball is there unless he removes it.There is a check valve in the filter that prevents drain back. | ||
ictfatboy |
Member Posts: 17 | Thanks for the info! From your site and other recommendations that 30 degree adapter is exactly what I need! | ||
ictfatboy |
Member Posts: 17 | Just one quick clarification and I am fairly certain I know the answer, but my 325 is a Poly and not a Hemi. My understanding is the only difference is the heads so the suggested 30 degree adapter from Hot Heads should fit. Am I correct in that assumption? | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Yes, no difference in the block. | ||
Richbo |
Veteran Posts: 242 Location: 33844 | Or search ebay for adapter that has filter straight out. | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | ...or use a remote package...... | ||
