Power Steering fluid level check.
Jfhelfrich
Posted 2019-04-12 7:30 PM (#580793)
Subject: Power Steering fluid level check.
1957 Belvedere power steering leak.
Wanted to check the fluid level before adding more.
No dipstick.
Any suggestions?
Posted 2019-04-12 7:45 PM (#580796 - in reply to #580793)
Subject: Re: Power Steering fluid level check.
50002000100100100252525
Not sure about 57 (different system) but later years when running and hot, bottom of the neck.
Phil_the_frenchie
Posted 2019-04-13 4:55 AM (#580814 - in reply to #580793)
500100100100100
On my '57 Imperial it's indeed at the bottom of the neck.
Posted 2019-04-13 12:30 PM (#580824 - in reply to #580793)
Subject: RE: Power Steering fluid level check.
200010005001001002525
If the pump has no filler neck and has a removable cover, as long as the fluid covers the filter you're OK. If no filter, 1/2" below the rim of the reservoir is OK/
Jfhelfrich
Posted 2019-04-13 4:43 PM (#580829 - in reply to #580793)
Thanks, guys.
Got it worked out.
