56 Plymouth
Muffin1
Posted 2019-05-19 12:21 PM (#582286)
Subject: 56 Plymouth
100100
I want to change my 56 Plymouth from a automatic transmission to a stick on the column
I have a 277 V8 and it is a 56 engine I checked the numbers
I need a bell housing a fly wheel and clutch plate, transmission
steering column , and the brake and clutch petals
and what else do I need for this conversion ?
Any other help would be a appreciated
Thanks Alex
I have two NOS V8 universal joints for the drive shaft { Body } maybe we can do some trading ??
58coupe
Posted 2019-05-19 12:29 PM (#582289 - in reply to #582286)
Subject: Re: 56 Plymouth
10001001001001002525
You will also need the clutch cross shaft and linkage and the driveshaft may be a different length. You will have to rewire the start circuit because it now goes through a neutral safety switch on the trans.
mwoss
Posted 2019-06-07 7:11 AM (#583056 - in reply to #582286)
Might be able to help you out with some of the stuff have to check shipping is going to cost a lot very heavy stuff where are you located
Thanks Mike
Posted 2019-06-07 8:09 AM (#583059 - in reply to #582289)
50005001001001001002525
58coupe - 2019-05-19 9:29 AM You will have to rewire the start circuit because it now goes through a neutral safety switch on the trans.
No he won't unless he changes the starter solenoid from a three lug to a four lug. If he doesn't change it, he could start in any gear (Neutral would be the wisest choice)
REFERENCE: Neutral Safety Switch - A compilation of info: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69708&...
jerrybev
Posted 2019-06-09 6:36 PM (#583167 - in reply to #582286)
Subject: RE: 56 Plymouth (also a few 1955 parts)
500
hi
I have a 56 steering column $50.
Jerry Whitfield
Winston salem, N.C. 1 hour 15 minutes north of Charlotte. I do not come to this site often, so, best to call me at 336-749-5922
Here is a full list of what I have for sale,
PARTS FOR SALE
NOS : all $20 each: Temp gages, fuel gage, thermostat , oil pressure gage #13751A, headlight switch, VOLTAGE REGULATOR, NOS FUEL PUMP FOR V8 ENGINE $45, 1955-56, MASTER CYLINDER REPAIR KIT, $10THERMOSTAT 1955-56 PLY-DODGE NOS $10, WAGNER WHEEL CYLINDER KIT WK11345 NOS HAVE 2, $5 EACH, WAGNER WHEEL CYLINDER KIT WK11345 NOS HAVE 2, $5 EACH, BRAKE WHEEL CYLINDER REPAIR KIT FROM NAPA PART #201 & PART NO 212 HAVE 2 , $5 EACH, VOLTAGE REGULATOR $20, IGNITION RESISTOR V8# FROM A.L. WELLS CO. #795 $5, NAPA ROTOR HAVE 2 IN SAME BOX, # AL 125, HAVE 3, $2 EACH, GENERATOR BRUSHES NEW TUNGSTEN E46X, $5 HAVE 2, WAGNER WHEEL CYLINDER KIT WK11345 HAVE 2, $5 EACH, SBI 2 OIL SEALS $5, HUSKY PLUG WIRES $11 # V4080-8HES, $20, #1688647, THERMOSTAT NEW $10 (HAVE 2) , WATER PUMP REBUILT FOR V8 $20, IDLER ARM REPAIR KIT $20
USED: FREE 1956 POWERFLITE TRANSMISSION, OUTER GAS DOOR $10, TURQ COLOR, HOOD LATCH, GOOD WORKING CONDITION, $10, DISTRIBUTO HUBCAPS, $20 each, HOOD BIRD $35, CIGARETTE LIGHTER COMPLETE UNIT $25, RADIO, A.M. $65, BARREL CARB Carter WCFB 2202SA $70,2 318” POLY VALVE COVERS, NOT DENTED, $25 PR, 1955-56 SPEEDOMETER $25, 1956 SHIFT CABLES FOR TRANSMISSION POWERFLITE $12, POWERFLITE SHIFTER, WORKING CONDITION $75, DIPSTICK TUBE, POWERFLITE $10, CARB CHOKE $5, OIL BREATHER CAP $5, GENERATOR FAN DOUBLE PULLEY CAST IRON $30, CRANK SHAFT DAMPER PULLEY (2 GROOVES) FOR 8 CYL $12, WATER PUMP DOUBLE PULLEY 8 CYL $20, GENERATOR USED $25, LEFT REAR BUMPER BRACKET FOR 55-56 CAR, $15, SINGLE WATER PUMP PULLEY , BLACK, CLEAN, USED $5, GENERATOR NO DRIVE ON BACK OF IT $25, WATER PUMP BYPASS HOSE WITH CLAMP $10, CRANKSHAFT PULLEY, SINGLE, CLEAN, USED $20, SEAST TRACKS RIGHT FRONT AND LEFT FRONT $5 EACH, STEERING COLUMN FOR MANUAL, App. 4 FEET TALL $50, HEATER CORE NO LEAKS $30, INSIDE AND OUTSIDE HEATER BLOWER BOX WITH MOTOR $20 EACH, MANUAL STEERING LINKAGE $25, Jerry Whitfield, 2128 Leeds Lane, Winston Salem, N.C. 27103, phone 336-765-8312 or 336-749-5922 member #123109
jerrybev
Posted 2019-06-09 6:39 PM (#583168 - in reply to #582286)
500
PARTS FOR SALE
USED: FREE 1956 POWERFLITE TRANSMISSION, OUTER GAS DOOR $10, TURQ COLOR, HOOD LATCH, GOOD WORKING CONDITION, $10, DISTRIBUTO HUBCAPS, $20 each, HOOD BIRD $35, CIGARETTE LIGHTER COMPLETE UNIT $25, RADIO, A.M. $65, BARREL CARB Carter WCFB 2202SA $70,2 318” POLY VALVE COVERS, NOT DENTED, $25 PR, 1955-56 SPEEDOMETER $25, 1956 SHIFT CABLES FOR TRANSMISSION POWERFLITE $12, POWERFLITE SHIFTER, WORKING CONDITION $75, DIPSTICK TUBE, POWERFLITE $10, CARB CHOKE $5, OIL BREATHER CAP $5, GENERATOR FAN DOUBLE PULLEY CAST IRON $30, CRANK SHAFT DAMPER PULLEY (2 GROOVES) FOR 8 CYL $12, WATER PUMP DOUBLE PULLEY 8 CYL $20, GENERATOR USED $25, LEFT REAR BUMPER BRACKET FOR 55-56 CAR, $15, SINGLE WATER PUMP PULLEY , BLACK, CLEAN, USED $5, GENERATOR NO DRIVE ON BACK OF IT $25, WATER PUMP BYPASS HOSE WITH CLAMP $10, CRANKSHAFT PULLEY, SINGLE, CLEAN, USED $20, SEAST TRACKS RIGHT FRONT AND LEFT FRONT $5 EACH, STEERING COLUMN FOR MANUAL, App. 4 FEET TALL $50, HEATER CORE NO LEAKS $30, INSIDE AND OUTSIDE HEATER BLOWER BOX WITH MOTOR $20 EACH, MANUAL STEERING LINKAGE $25, Jerry Whitfield, 2128 Leeds Lane, Winston Salem, N.C. 27103, phone 336-749-5922 or 336-765-8312 member #123109
