Identify Mopar 8 1/4 rear axle Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Early Mopar 8 1/4 axles were used, as I know, in 6 cylinder cars in the Forward Look Era (and beyond). They are a banjo or Hotchkiss design just like a Mopar 8 3/4 or Ford 9 inch differential. So if you were in a junk yard or in some other situation where you couldn't remove the diff and measure the ring gear diameter, how would you identify the rear axle as a 8 1/4 versus a 8 3/4? I know the early 8 3/4 had a casting number that ends in "657" (similar to later ones having 741, 741 or 489), but what would a 8 1/4 have? How about mounting studs? 8 3/4 has 10 studs, how many does the 8 1/4 have? Any other unique features to look for to ID the early 8 1/4 rear diffs? Thanks. | ||
Expert 5K+ Posts: 9654 Location: So. Cal | My '56 Plymouth 8 1/4 rear end had a fill plug in the back of it. I assume that it was required because there wasn't a fill plug cast into the pig. I'm not sure if later ones have that or not. Edited by Powerflite 2019-05-23 9:43 PM | ||
Expert Posts: 3776 Location: NorCal | The pre-'62 8 1/4" housing has a casting number that ends in 448 and has 11 attaching studs/nuts. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Perfect, thank you! | ||
westaus29 |
Veteran Posts: 148 Location: Mandurah, Western Australia | My Detroit built '55 Plymouth Belvedere Suburban V8 diff is banjo style and I believe 8 1/4. It has 11 studs, but casting number ends in 544 (casting marking A 1141544 10-11-55 B) and ratio is 3.9. I have concluded it is a substitute from an Aussie Plymouth, which retained the earlier 53-54 design, confirmed by checking a couple of junkyard chassis. So there may be earlier diffs which are similar to 55/56. I am trying to figure out how to change to original 3,54 ratio and 11 inch brakes, as per original and am keen to learn more. It has been suggested I look for a later back axle but those are pretty rare in Oz .. only one I have seen in 12 months looking was $1500, a bit beyond my budget. The problem is the parts book has part numbers but the diff carrier only has a casting number. I have ordered a 53-54 parts list CD to try and learn more. | ||
Space Trukin Wagon |
Extreme Veteran Posts: 427 Location: Ohio | 57chizler - 2019-05-23 3:20 PM The pre-'62 8 1/4" housing has a casting number that ends in 448 and has 11 attaching studs/nuts. The 11 -vs- 10 mounting studs to ID the difference between the 8-1/4 and 8-3/4 is excellent info. This has been confirmed on two axles that I have. In addition the factory parts manual calls out the casting numbers as way to ID the axles when servicing / ordering parts. See attached photo from 1960 parts manual. The last line in the "Notes" section it states casting: > 1828488 is 8-1/4 > 1820657 is 8-3/4 Also when confirming the casting numbers on the rear carrier section the 8-1/4 embossed number is located between the two ribs on the drivers side. Wheres the 8-3/4 embossed number was located as expected on the lower edge of the rear carrier which is also the same location for later 741, 742 and 489 8-3/4 carriers. - Photo attached showing the location of part number on the 8-1/4 Edited by Space Trukin Wagon 2019-05-27 9:09 AM (Rear Axle_Parts Manual.JPG) (Rear Axle_8.25 Casting.JPG) Attachments ---------------- Rear Axle_Parts Manual.JPG (35KB - 378 downloads) Rear Axle_8.25 Casting.JPG (38KB - 330 downloads) | ||
westaus29 |
Veteran Posts: 148 Location: Mandurah, Western Australia | That info on the casting numbers, in particular the last three digits, helps make sense of some of the other discussion Ive read on diffs. The 55-59 parts manuals dont mention casting numbers, and I had never looked at the 60 parts manual even tho its on the same cd. Learning all the time! There is also info about what diffs go in what mopar on the interchange manual on http://www.mymopar.com/index.php?pid=107 I am still trying to figure out how to interpret it. | ||
Expert Posts: 3776 Location: NorCal | Regarding the casting number; from my experience, the casting number is often one digit off from the part number. The part number for the '58-'61 8 1/4" housing is 1828447 which coincides with 1828448 being the casting number. | ||
imp610 |
Veteran Posts: 129 Location: Finland | Great to find this discussion! Found out that we have a 8 1/4 axle in our 1960 Belvedere, was planning to replace the pinion seal, but before disassembly searching the web I canĀ“t find any info of is there a crush sleeve or a spacer between the pinion bearings? Just to be sure before giving the pinion nut some force, has it to be marked versus the yoke and count revolutions out/in or just torque back in specs an then again how much would that be in ft.lbs? Anybody done this? | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | . I don't believe that there is a crush washer/sleeve in those 8.25" rear diffs (at least that is what I was told when I did my rear seal). Others with more experience will correct me if I am wrong I think that your pinion ("yoke") seal will be PN 1738831 which crosses to Timken 5126 https://mibearings.com/index.php?main_page=product_info&products_id=... https://www.motionindustries.com/products/sku/01314480 Torque on the nut is 250 lb-ft. (1960RearDiff_1.jpg) (1960RearDiff_2.jpg) Attachments ---------------- 1960RearDiff_1.jpg (141KB - 353 downloads) 1960RearDiff_2.jpg (179KB - 213 downloads) | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Crush sleeves is a newer technology that didn't come out until later. I just put non-crush sleeve yolks on TITE with my large air gun. Edited by Powerflite 2021-02-03 12:04 PM | ||
imp610 |
Veteran Posts: 129 Location: Finland | Great news! I have a National #5126 inhand to install. Just removed the nut and yoke, man that was tight... Reguired a 4 feet long bar and my son to step on, and he ways about 150 pounds! How much is the torque to tighten the nut? Is it the same as with the 8 3/4 rear end? Been reading from various sources 210 or 240 lbs? | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | imp610 - 2021-02-03 9:30 AM Great news! I have a National #5126 inhand to install. Just removed the nut and yoke, man that was tight... Reguired a 4 feet long bar and my son to step on, and he ways about 150 pounds! How much is the torque to tighten the nut? Is it the same as with the 8 3/4 rear end? Been reading from various sources 210 or 240 lbs? I guess that you didn't believe me when I said 250 lb-ft. Okay, I lied. The manual says 240 lb-ft (min). Edited by 56D500boy 2021-02-03 1:02 PM (1960RearDiff_3.jpg) Attachments ---------------- 1960RearDiff_3.jpg (85KB - 201 downloads) | ||
imp610 |
Veteran Posts: 129 Location: Finland | Ok so 240 ft. lbs it is Edited by imp610 2021-02-04 2:39 AM | ||
