Location: Chattanooga | What engine would a 1961 Chrysler Windsor have? Were there optional engines available for the Windsor, like a 413? |
Location: So. Cal | It would have the 383 RB motor. From the outside, it looks identical to the 413 with the same intake etc, but a smaller bore size. The newly designated Newport, which was similar to the Windsor, would have come with the 361 B motor. I seriously doubt that you could have got a 413 in a Windsor because they would most likely have had you upgrade to the New Yorker instead. But I don't know this for certain. |
Location: northern germany | Powerflite - 2019-05-25 10:07 AM
No again. The same question has been asked a couple of weeks ago. The RB 383 was 59/60 US-Chrysler ONLY. Fortunately the switched to the 383-B for the 1961 model year. |
Location: So. Cal | Thanks for the correction. I thought they continued to '61, apparently a common misconception. |
Location: northern germany | 1958300 - 2019-05-23 10:40 PM
I believe not officially but if you had the right connections, everything was available from Chrysler.
Edited by 1960fury 2019-05-25 10:21 AM
