70 to 73 discs on a 61?
Apollo 61
Posted 2019-06-04 3:46 AM (#582910)
Subject: 70 to 73 discs on a 61?
5001001002525
Will disc brakes from a 70 Chrysler 300 bolt on a 61?
Edited by Apollo 61 2019-06-04 3:47 AM
Mopar1
Posted 2019-06-04 10:42 AM (#582920 - in reply to #582910)
Subject: Re: 70 to 73 discs on a 61?
2000100025
You'll probably have to swap the spindles. I used '77 NYer on my '60 Plym. The A Arm mounts were a little closer than OEM, but they work fine on mine. You'll just have to check.
bad58mike
Posted 2019-06-04 11:16 AM (#582923 - in reply to #582910)
Subject: RE: 70 to 73 discs on a 61?
10001002525
apollo61, I have a complete AAJ brakes disc brake kit for your 61, bolt on kit. would be maybe willing to trade for your 70 chrysler 300 disc brakes, I'll need your spindles too.
send me a pm we can talk.
thanks
Mike
Stroller
Posted 2019-06-07 2:14 PM (#583073 - in reply to #582910)
1001001002525
I was once told by an old friend that my '60 Fury letter designation was most like a C body mopar. When I asked about the disk conversion with knuckles for caliper mounts he told me I would have to change the lower ball joint because the taper diameter is different. I might try it if I ever get a brake and clutch pedal assembly first because without I don't need brakes.
Apollo 61
Posted 2019-06-14 2:10 AM (#583412 - in reply to #583073)
5001001002525
Stroller - 2019-06-07 2:14 PM
Are these the pedals your looking for? If so I got these from a 61 ply parts car. You have some PMs
Edited by Apollo 61 2019-06-14 2:29 AM
Attachments image.jpeg (223KB - 168 downloads)
