55 dodge royal trim and seals
gandalfgreyhame
Posted 2019-06-10 8:42 PM (#583253)
Subject: 55 dodge royal trim and seals
New User
My brother and I were lucky enough to each acquire a 55 royal. Different shades of blue, slightly
Different options. Our problems are that we can find no reliable info for getting front and rear window
Seals and how to install them. Also can't find out how the trim attaches to those seals as well
As putting body trim in place. Since we have had no luck, we decided to go to the expert's
Thanks so much for any help
Edited by gandalfgreyhame 2019-06-10 8:44 PM
Posted 2019-06-10 9:50 PM (#583258 - in reply to #583253)
Subject: RE: 55 dodge royal trim and seals
500020002000500100100100100
For the how to, down load and save the 55/56 Plymouth pdf service manual from this website:
http://www.mymopar.com/index.php?pid=109
For the gaskets you can try Steele Rubber (I selected 4dr sedan, if that is wrong, you'll need to change the search):
https://www.steelerubber.com/search?year=1955&make=dodge&model=royal...
OR Andy Bernbaum:
https://www.oldmoparts.com/parts-exterior-rubber.aspx
