60 CHRYSLER wheel studs
60fintasticfly
Posted 2019-06-17 10:43 AM (#583563)
Subject: 60 CHRYSLER wheel studs
does anyone know where I can buy left hand thread wheel studs , and right hand thread ?? 1960 Chrysler Windsor … thanks very much
Posted 2019-06-17 11:04 AM (#583566 - in reply to #583563)
Subject: Re: 60 CHRYSLER wheel studs
500010001001001001002525
Napa is a good source for the right hand threaded studs. I don't think the left hand versions are available new. If you want them, get them used.
60fintasticfly
Posted 2019-06-17 2:05 PM (#583577 - in reply to #583566)
thank you, just tried napa , the guy said he doesn't see anything so far in his database
60fintasticfly
Posted 2019-06-17 2:14 PM (#583580 - in reply to #583577)
now he just called me back and said he can get the right hand thread , so you are right , and thank you
59 in Calif
Posted 2019-06-17 2:34 PM (#583582 - in reply to #583563)
change the left hand thread studs to right hand. you will be glad you did, and no one will know the difference. and the wheel won't fall off either. Did it on my 65 New Yorker and the 59 dodge too!! Jerry
60fintasticfly
Posted 2019-06-23 12:38 PM (#583936 - in reply to #583582)
wow, cool, thanks , much appreciated !!!!
chefothefuture
Posted 2019-06-27 6:57 PM (#584144 - in reply to #583563)
Or you can get these-
https://www.ebay.com/itm/Wheel-Lug-Stud-Bolt-1-2-20L-1-9-16-645-Knur...
You'll need at least a 20 ton press and a die.
