1959 Fury Rear Axle Flange Studs
1959SportFuryPaul
Posted 2019-08-20 7:27 AM (#586275)
Subject: 1959 Fury Rear Axle Flange Studs
New User
While replacing the rear brakes and refinishing the brake backing plates I noticed 2-of-the-5 rear axle flange studs that attach the backing plate are stripped. I'm looking for either the original OEM part number or a source for the correct parts. Any help would be appreciated.
Posted 2019-08-20 1:38 PM (#586288 - in reply to #586275)
Subject: RE: 1959 Fury Rear Axle Flange Studs
20001000100100100
Original P/N is 1484632. Not sure if the later version will work but Doc Diff has them:
https://www.doctordiff.com/mopar-housing-end-stud-kit.html
