Driver's Side Mirror for a 1955 New Yorker Deluxe St. Regis
JKelly0657
Posted 2019-09-07 5:08 PM (#587221)
Subject: Driver's Side Mirror for a 1955 New Yorker Deluxe St. Regis
Continuing to work on my 1955 St. Regis. The new interior is nearly finished and is looking really nice. My exterior rear view mirror is pitted and the mirror needs restoring. I have been looking for a new, accurate repro replacement with no luck. My mirror has a small, slightly angled shaft on one end (the end toward the rear of the car) of the mount that hooks into a tiny hole on the door. A screw goes through the other end of the mount (toward the front of the car) and into a small flat brace that sticks up through a second hole above the surface of the door. The screw goes horizonally through the recessed end of the mount into the little flat brace and when you tighten the screw it pulls the angled shaft back tight against the door surface. This is a neat setup because you don't see any screws on the base. There is a repro mirror that looks like my original but the little shaft and the screw hole on the mount are reversed from my original and thus wlll not work for me. I can get my mirror re-silvered and re-chromed but would like to find a new one if possible. Does anyone know of a vendor that sells an accurate reproduction for my '55 New Yorker?
Joe
