Ball joint repair kit.
local2Ed
Posted 2019-10-29 6:08 PM (#589489)
Subject: Ball joint repair kit.
I've seen these advertised before but don't quite understand what they are supposed to "repair" on the ball joint.
I don't plan on buying them or using them but I was just curious how these repair the ball joint.
https://www.ebay.com/itm/1957-1958-1959-1960-1961-Chrysler-Dodge-Ply...
Posted 2019-10-30 1:40 AM (#589513 - in reply to #589489)
Subject: Re: Ball joint repair kit.
20001000500100100100100252525
ball joints weren't sealed like they are today, so you just rebuild the bushings. It was kind of a hack job though.
It kind of places a shim in between. I would understand they cant give these away. You can get a moog new for like 20$.
local2Ed
Posted 2019-11-02 8:37 AM (#589607 - in reply to #589489)
Thanks, didn't know the ball joints could be taken apart.
Posted 2019-11-02 9:01 AM (#589608 - in reply to #589607)
5000100010010010010025
local2Ed - 2019-11-02 8:37 AM
Actually you can't. Of course you can grind/cut them open carefully and then you could rebuild them. The aftermarket ball joint "repair kits" I understand go on the outside.
I have a very rare MOOG (still 50s/60s quality) NOS rebuildable/adjustable lower ball joint pair. These have threaded covers. If someone is interested?
Edited by 1960fury 2019-11-02 9:04 AM
