1957 Dodge with torqueflight slow to engage Drive
Mr. Bob
Posted 2019-11-03 1:47 PM (#589673)
Subject: 1957 Dodge with torqueflight slow to engage Drive
My 57 Dodge promptly shifts into reverse to back it out of the shop.
But it then takes 15 - 30 seconds to engage Drive and move forward. Does the same if I try 1st or 2nd gears instead. Once it engages, it drives just fine and is usually good for the rest of the day.
Thoughts?
Posted 2019-11-03 3:39 PM (#589675 - in reply to #589673)
Subject: RE: 1957 Dodge with torqueflight slow to engage Drive
20001000500100100252525
This is usually caused by shrunken/hardened seals in the front clutch. The front clutch is used for all forward gears but not Reverse.
An additive like Trans-X or Lucas will soften the seals and restore function. If not, an overhaul is in the future.
Mr. Bob
Posted 2019-11-04 9:56 PM (#589719 - in reply to #589673)
Subject: Re: 1957 Dodge with torqueflight slow to engage Drive
WOW! I was skeptical of the claim on the Lucas bottle of "Results Are Usually Immediate". But after idling for 15 minutes after I poured it in, the car shifted properly into drive like it was new.
THANK YOU!!!!!!!
