1958 plymouth trans cable adjustment issue..
johnnybuick
Posted 2019-12-11 9:42 AM (#591441)
Subject: 1958 plymouth trans cable adjustment issue..
Can anyone offer advice on how to correctly re fit/adjust the 1958 plymouth push button trans cable... once cable has been removed from the torqueflite trans ? My mechanic removed cable then put it back and now i have no reverse ..just 1st gear and that is sluggish.. any help would be greatfully appreciated..
Posted 2019-12-11 3:25 PM (#591456 - in reply to #591441)
Subject: RE: 1958 plymouth trans cable adjustment issue..
20001000100100100
From the FSM:
(Cable.PNG)
(Cable.PNG)
Attachments Cable.PNG (44KB - 9 downloads)
Attachments Cable.PNG (29KB - 10 downloads)
johnnybuick
Posted 2019-12-12 7:38 AM (#591482 - in reply to #591441)
Subject: Re: 1958 plymouth trans cable adjustment issue..
Thanks 57 .. used your info and got cable back in and working... apparently it was a very sensitive adjustment infact hairline movement on that adjustment bracket..truly appreciate your efforts with that .. you put me back on the road...
cheers n beers to you my friend !!
Edited by johnnybuick 2019-12-12 7:40 AM
