1955 Plymouth Carter 2BBL BBD for Overdrive
55PLBVSP
Posted 2020-01-09 9:14 PM (#592710)
Subject: 1955 Plymouth Carter 2BBL BBD for Overdrive
Am looking for a Carter 2BBL BBD Carburetor with Overdrive Switch and linkage for a 1955 Plymouth Belvedere 259 V8 three speed manual W/OD. The number in the Factory Service Manual shows it to be a 2260S. There is also reference to the kickdown switch being a 192-34U. I found a Carter document that says a 2274SA can replace a 2260S -SA -or-SB.
Thank You
mobileparts
Posted 2020-01-10 9:53 AM (#592737 - in reply to #592710)
Subject: Re: 1955 Plymouth Carter 2BBL BBD for Overdrive
100100
If you are unsuccessful in your quest for a carburetor,
I can supply you with a kit, that is ethanol gas compatible
material.....
Call if you need or want -- Craig -- 516 - 485 - 1935....
