Gas tank Sending unit gasket
Mopar1
Posted 2020-01-16 11:51 AM (#593035)
Subject: Gas tank Sending unit gasket
2000100025
I had a link to sheets of material on E Bay to cut out gaskets, but I lost the bookmark. Anyone got the link?
Posted 2020-01-16 1:15 PM (#593040 - in reply to #593035)
Subject: Re: Gas tank Sending unit gasket
50001000100100100100252525
Rubber: https://www.ebay.com/itm/1957-1958-1959-1960-Chevy-Fuel-Tank-Sending...
Or cork:
https://www.ebay.com/itm/1955-1956-1957-Chevy-195D-FUEL-GAS-TANK-SEN...
Posted 2020-01-16 4:11 PM (#593044 - in reply to #593035)
50002000100100100252525
You basically only need a sheet of fuel resistant rubber. I have one left that worked great for my 60 Fury xx years ago. If you want I can measure the thickness, so you know what to buy. IIRC it was 2mm, that is around 5/64".
Surprisingly I couldn't find any affordable Nitrile sheets on Ebay.com! Found this on Ebay UK:
https://www.ebay.com/itm/Solid-Flat-Nitrile-NBR-Seal-Ring-2mm-thk-Ma...
Edited by 1960fury 2020-01-16 4:21 PM
60 dart
Posted 2020-01-16 11:41 PM (#593073 - in reply to #593035)
50002000100050010010010010025
what ever you use put some good sealer on both sides , medium lightly ------------------------------------------------------later
Posted 2020-01-17 6:40 AM (#593084 - in reply to #593035)
If the gasket has the correct thickness (crush) no sealer is needed.
Edited by 1960fury 2020-01-17 6:41 AM
Mopar1
Posted 2020-01-17 11:05 AM (#593090 - in reply to #593040)
2000100025
mstrug - 2020-01-16 12:15 PM
Or cork:
https://www.ebay.com/itm/1955-1956-1957-Chevy-195D-FUEL-GAS-TANK-SEN... seem to be Cork-Nitral. So the Chevy is the same as Mopar? Interesting.
Mopar1
Posted 2020-01-17 11:06 AM (#593093 - in reply to #593084)
2000100025
1960fury - 2020-01-17 5:40 AM
And...not aware of any that is ethanol proof...
Posted 2020-01-17 1:22 PM (#593103 - in reply to #593035)
500050002000100025
Use Viton rubber, will withstand modern fuel and ethanol.
The right thickness is important, so measure with cardboard. Apply a thin layer of silicone grease. No sealer needed.
The correct measurements for '60 Chrysler is Ø 75mm X Ø 51mm X thickness 1,5mm) (Ø 2.9500" X Ø 2" X thickness .0600")
Check and confirm
Mopar1
Posted 2020-02-07 11:15 AM (#593914 - in reply to #593044)
2000100025
1960fury - 2020-01-16 3:11 PM
https://www.ebay.com/itm/Solid-Flat-Nitrile-NBR-Seal-Ring-2mm-thk-Ma... you have an original gasket that could be measured that would be great.
Posted 2020-02-08 7:58 AM (#593945 - in reply to #593914)
Mopar1 - 2020-02-07 11:15 AM
The thickness that worked for me is 2mm, the outer diameter is 3" the inner 2. 3/16". Hope that helps.
I would send you a seal cut out of my remaining stock for the postage, but the German post now (hard to believe, but true) does not allow shipping of any goods in an envelope as a "letter", just correspondence. As soon as any goods are shipped, crazy prices apply for international shipping.
Edited by 1960fury 2020-02-08 8:09 AM
Mopar1
Posted 2020-02-08 2:14 PM (#593953 - in reply to #593945)
2000100025
1960fury - 2020-02-08 6:58 AM
OK! Thanks!
60 dart
Posted 2020-02-16 1:02 AM (#594352 - in reply to #593035)
these don't work no more? ---------------------------------------------------later
https://www.ebay.com/itm/Mopar-Fuel-Gas-Tank-Sending-Unit-Lock-Ring-...
Posted 2020-02-16 7:12 AM (#594359 - in reply to #593035)
Yes, they should. Stupid me, I posted that link in another thread (about lock rings) not long ago and competely forgot about it.
Mopar1
Posted 2020-02-25 6:40 PM (#594823 - in reply to #594352)
2000100025
60 dart - 2020-02-16 12:02 AM
https://www.ebay.com/itm/Mopar-Fuel-Gas-Tank-Sending-Unit-Lock-Ring-... I've tried the gaskets listed at the muscle car resto places & they don't seal. Seen comments that they are thinner than the FL era ones. Tried 1, 2 glued together, still leaks. I'm fixing to order something, just trying to figure out what.
Mopar1
Posted 2020-02-25 6:42 PM (#594824 - in reply to #594823)
2000100025
The old tank leaked. Then it rusted out in the seams and replaced, same lack of sealing with the new one.
