pitman arm removal ? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | whats a good cost effective pitman arm removal tool that actually does the job ------------------------------------------------later | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Good question! Years ago I rented a specialized HD Snap on puller ——— ruined it!! Just went and got another complete steering gear. Pulled that pitman arm no problem. Greg | ||
Expert 5K+ Posts: 5006 | i cut mine... i was swapping a dodge on a chrysler anyways | ||
Board Moderator & Exner Expert 10K+ Posts: 13042 Location: Southern Sweden - Sturkö island | To remove the pitman arm with the steering gear in the car is a drama since there's no good space for a heavy duty puller. For this reason, I will build a puller simular to the one shown in the fsm. With the steering gear out of the car, it's important to have a heavy duty two arm puller with a crosswise reinforcement arm that holds the legs together. I use a big wise for this instead. (Styrinrrrttning_Fig_22-rez.jpg) Attachments ---------------- Styrinrrrttning_Fig_22-rez.jpg (108KB - 275 downloads) | ||
mstrug |
Expert 5K+ Posts: 6487 Location: Newark, Texas (Fort Worth) | Might have to heat the outside of the arm, then tap with hammer while pulling with a slide hammer/hook assembly. | ||
Board Moderator & Exner Expert 10K+ Posts: 13042 Location: Southern Sweden - Sturkö island | As for tapping/hitting with a hammer - a photo of the broken ball-guide from the steering gear I recently renovated. Someone has beaten on both the ingoing and the outgoing shaft..…… Slidehammer wont work - the pitman arms are really tight and after years of rust creeping into the splines. (Resized_20200113_124519.png) Attachments ---------------- Resized_20200113_124519.png (694KB - 317 downloads) | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | bought one two piece that was too small . tried a two legged puller , but went sideways while tightening . the next step will be buying a bigger two piece puller or a truck sized puller like wiz posted . as to heating/bigger hammer theory , i tried that with the two legged puller as tight as i could get it without twisting the puller too far sideways . the trick is here i think is to find a puller i can get super tight without slipping off , a little more heat without damage , and a bigger hammer . as of right now i've had it soaking for two days with kroil adding just a little as it seeks to spread ,,,,, thanks guys and i'm still open to puller suggestions . i've never had one this tight --------------------------------later | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | so i bought two more tools . one like wiz posted but smaller than ford truck and one u shaped bigger than the first one i bought . now to wait for em to get here ----------------------------------------------later | ||
Expert 5K+ Posts: 5006 | i tried heat... hitting and pulling and all that... was impossible to budge... | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | 60 dart - 2020-01-20 5:34 PM so i bought two more tools . one like wiz posted but smaller than ford truck and one u shaped bigger than the first one i bought . now to wait for em to get here ----------------------------------------------later I wish you luck. I successfully pulled probably more than a dozen of them with just basic pullers but I pulled all of these in my shop with the steering gear out of the car. All/most of these off junkyard cars where they had been down in the dirt but the one I posted about earlier, I scrapped the entire assembly! But, that was in the days of "plenty"! It was off a Chrysler so the pitman arm is different from a Dodge and I didn't need another Chrysler arm! Greg | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | it's goin to come off ,,,,, one way or another --------------------------------------------------later | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | received this one of which just fits with no extra space . might be the best one out of the bunch . yrs. ago the last one i took off was with wood wedges . a lot of em ------------------------------------------later https://www.ebay.com/sch/i.html?_odkw=Dodge+%281960%2C60%2C%2760... | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | You ever get that pitman arm off that steering gear Chuck? | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | yes sir with the puller from epay ---------------------------------------------------later | ||
mstrug |
Expert 5K+ Posts: 6487 Location: Newark, Texas (Fort Worth) | Best price: https://www.ebay.com/sch/i.html?_fspt=1&_from=R40&_nkw=OTC+8149+Pitm... | ||
Expert 5K+ Posts: 5006 | hah stand behind a shield when using one of those.., get well protected... the pressure is insane, if that thing shattered it would be like a hand grenade going off. Even the chinese stuff is correctly heat treated though it looks. I just cut my old one off since i wasnt going to use it, it slid right off | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | hah stand behind a shield when using one of those . used the 8149 and came right off with hardly any effort , some times the chinese tools work great with some luck --------------------------------------------later | ||
