what type filter for remote tranny filter?
udoittwo
Posted 2020-02-02 9:27 AM (#593730)
Subject: what type filter for remote tranny filter?
100010010010025
I have an old remote water separator filter set up from my old boat. I haven't looked at it in years but I am thinking of adding a remote trans. filter.
I know is sitting on a shelf somewhere and as I recall and it looks just like a remote oil filter. Maybe it has a pressure or check valve or something inside?
Anyway, whether I can use it or buy one, what filter is used? Can I just use a regular oil filter?
Posted 2020-02-02 4:27 PM (#593742 - in reply to #593730)
Subject: RE: what type filter for remote tranny filter?
200010005001001002525
I have installed several remote inline ATF filters and use the Mopar/Ford PH8 style spin-on oil filter. For a canister type I would use the recommended oil filter element. ATF is just oil.
Mopar1
Posted 2020-02-04 11:23 AM (#593791 - in reply to #593730)
Subject: Re: what type filter for remote tranny filter?
2000100025
I used the commonly available remote spin ons that you can order from Summit & Jegs. Wix or Motorcraft filters. They list spin on filters for trannys, but the filters have the GM threads instead of the Ford/Mopar ones the base uses.
