Throttle shaft repair
lonesome mopar
Posted 2020-02-11 6:39 AM (#594056)
Subject: Throttle shaft repair
100100100252525
Hi gang,
my throttle won't return to idle as immediatly as it used to do.
The spring is new but the accelerator rod still does not seat  the shaft to the full idle position.
Just a few hudred rpm off idle.
To seat it back, I have to push it back with my finger. Then it's ok.
So I guessed the throttle shaft bushings must be worn out of round....
Does anybody know if the following throttle shaft bushing repair kit is suitable for my stock AFB Carter carburetor?
https://www.ebay.com/itm/Carburetor-5-16-Throttle-Shaft-Bushing-Repair-Kit-8-Bushings-16-Screws-Reamer/331997014383?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I thank you for any hint.
Posted 2020-02-11 8:06 AM (#594059 - in reply to #594056)
Subject: Re: Throttle shaft repair
50002000100100100252525
??? If it is worn it usually gives free-play and is not binding. "New spring"? So not OE? Just install a OE or stronger spring or increase the tension!
Posted 2020-02-11 8:21 AM (#594061 - in reply to #594056)
500050002000100025
As Sid wrote - and normally, I rarely find a throttle shat that's so worn that it creates problems.
First of all, check the fulcrum bracket on the firewall - is that worn?
Secondly, check the throttle valve lever rubber bushing on the automatic transmission - is that worn or totally missing?
Thirdly, loosen the nut on the throttle valve rod adjustment and leave the nut off - do this get the engine back to normal idle rpm's?
It's very important that the throttle valve rod/lever is properly adjusted (presuming that you have an automatic transmission in this car?)
Posted 2020-02-11 9:07 AM (#594062 - in reply to #594056)
I have never seen a throttle shat that was so worn that the plate jams in the bore. Of course I was assuming the kick down linkage is adjusted properly. If it prevents curb idle, it must be so off that the transmission slips when shifting.
Edited by 1960fury 2020-02-11 9:08 AM
lonesome mopar
Posted 2020-02-11 11:55 AM (#594069 - in reply to #594056)
100100100252525
Thanks for the hints.
all right I'll check the stuff you are saying and I will come back...
By the way it was working well, approx a month ago, then little by little it started to stick.
Linkage is free and oiled. Rubber bushing old but not worn out.... Kick down well registered...
Car is my '58 Belvie 318 w/super pack option
I will double check and report.
lonesome mopar
Posted 2020-02-11 11:59 AM (#594070 - in reply to #594056)
100100100252525
The return spring is a replacement for stock 4 barrel carb, bought from summitracing.com
It worked fine for several months.
I do not believe it has lost its energy. It is quite strong - no need a stronger one or my foot will ache at highway speed.
Posted 2020-02-11 2:47 PM (#594081 - in reply to #594056)
500050002000100025
Check the heat riser and choke valve movements as next step...
60 dart
Posted 2020-02-12 12:10 AM (#594105 - in reply to #594056)
50002000100050010010010010025
try carb cleaner down the throat . over the yrs i've had a few with the same problem and a good cleaning fixed em all . mostly holley 94's-------------------------------------------------later
