Location: Muskego, WI | Looking for a single 4 barrel intake manifold for a 318 poly, factory or aftermarket. Let me know what you have an what you're asking.
Thanks. |
Location: ALABAMA, HEART OF DIXIE | there are three series of factory, (iron), manifolds for the 318. Early, 56/58 use the smaller WCFB carb. The 59/60 and 61/62 will accept the larger AFB.
Edited by rockerarm 2020-02-25 12:36 PM
Location: Muskego, WI | I plan on using a NEW 500 to 600 cfm carb, so would most likely need to be adapted either way. Just hoping to find something. |
Location: Williams California | jboymechanic - 2020-02-25 12:02 PM
I have one I picked up recently. I'll check the carb bolt pattern to see which it is.
---John |
| I have one that I believe is from a ‘57. It’s drilled for a wcfb but it has larger flanges cast that are the size of an afb. Would have to be machined for the afb to work. Pm me with your email or phone number and I can send you pictures of it. |
Location: Williams California | jboymechanic - 2020-02-25 9:15 PM
PM sent.
Jon, the one I have is a '58 on up, so a modern Holley or Carter will fit the bolt pattern.
---John |
Location: Muskego, WI | Manifold found and purchased. Thanks all. |
Location: WHEELING,WV.>>>HOME OF WWVA | if i were in the market for a 318 poly 4bbl intake , i'd have to give the air gap intake produced for chrysler power
some serious thought -------------------------------------------later |
Location: Muskego, WI | Just too much money Chuck, trying to get the car on the road on a budget. Just honing the cylinders, new rings and bearings and she's going back together. |
