Pre bent fuel lines for a 56
Twotallkris34
Posted 2020-03-29 3:41 PM (#596204)
Subject: Pre bent fuel lines for a 56
Hello All,
Looking to replace my fuel line on my 56 windsor from the tank to pump, anyone know any places that sell pre bent lines. If not what is everyone recommendation for rigid fuel line material ? Thanks all !!
Edited by Twotallkris34 2020-03-29 4:19 PM
Posted 2020-03-29 8:40 PM (#596212 - in reply to #596204)
Subject: Re: Pre bent fuel lines for a 56
50001000100100100100252525
Will a New Yorker work? https://classictube.com/product/chrysler-new-yorker-fuel-tank-to-pum... .CYF1008-SS is a Fuel – Fuel – Tank To Pump Line (2 Pc) For the 1956 Chrysler New Yorker Made in Stainless Steel Tubing. Classic Tube manufactures only the highest quality USA parts, so you can get the job done right the first time. $119.99.
Space Trukin Wagon
Posted 2020-03-30 12:17 AM (#596219 - in reply to #596204)
Subject: RE: Pre bent fuel lines for a 56
10010010010025
Do you have the original lines ?
Contact the manufacturers of the reproduction parts such as Fine Lines or Classic tubes and they should bend a set of lines for your car.
I know that Fine Lines will do this as long as they have the original line to use as a pattern.
Edited by Space Trukin Wagon 2020-03-30 12:18 AM
Twotallkris34
Posted 2020-03-30 9:20 PM (#596269 - in reply to #596204)
I will check out both options ! Thanks guys !!!
