Swivel seat question
RamPhoenix
Posted 2020-06-17 8:44 PM (#599798)
Subject: Swivel seat question
1002525
Are swivel seats from a 1959 Imperial the same size as the swivel seats from a 1959 Windsor?
Posted 2020-06-18 12:55 AM (#599801 - in reply to #599798)
Subject: Re: Swivel seat question
50005000200010010025
The seat frames Åre the same, but the foam is different
Posted 2020-06-18 6:33 AM (#599804 - in reply to #599798)
5000100050025
Had these fully reclining back rests?
Posted 2020-06-18 8:00 AM (#599805 - in reply to #599798)
No Sid, they fold forward only. In 4 door cars there are steek wedges that blocks the backrest.
Posted 2020-06-18 8:13 AM (#599806 - in reply to #599798)
5000100050025
Thanks for the answer. I asked because there is a bigger gap between the seat and the backrest on these. The standard seat backrest are very close to the seat and wouldn't decline even if there was a hinge. In order to make them fully declining backrests (I really miss that) one would have to raise the backrest (or change the pivot location to the rear). Not a big Problem but requires more work and a modification of the center backrest bracket. Actually I'm working on that. A design that does not alter the OE seat covers!
(Bless the DeSoto!.jpg)
(ctcdwtlltcd.jpg)
Attachments Bless the DeSoto!.jpg (37KB - 12 downloads)
Attachments ctcdwtlltcd.jpg (208KB - 11 downloads)
Posted 2020-06-18 10:42 AM (#599812 - in reply to #599798)
What's your plan Sid - Steamy windows???
Posted 2020-06-18 2:46 PM (#599826 - in reply to #599812)
5000100050025
wizard - 2020-06-18 10:42 AM
For that I should have added this 30+ years ago
Posted 2020-06-18 6:57 PM (#599832 - in reply to #599812)
200010005001001002525
I put a '59 Crown Imperial power swivel seat in my 1957 Chrysler that was equipped with a factory power seat.
Four bolt holes lined up perfectly, and I had to drill four new holes. But the seat physically fit in the car without a problem.
I think you could theoretically swap swivel seats out between a '59 Imperial and '59 Windsor, though they may not mount the same, and may not be exactly the "same size" as you asked. Hope that helps.
Edited by 57burb 2020-06-18 7:03 PM
(20180826_153213.jpg)
Attachments 20180826_153213.jpg (236KB - 12 downloads)
